NR7101 - Downgrade R13A04 to R13A02
Hello Everyone
Here on the forum several files have been shared that allow incremental downgrades such as:
"RG502QEAAAR13A02M4G-RG502QEAAAR11A07M4G" and "RG502QEAAAR11A06M4G-RG502QEAAAR11A03M4G"
it's possible to have also the downgrade:
"RG502QEAACR13A04M4G_ZYXEL-RG502QEAACR13A02M4G_ZYXEL" ?
It would be very important to have it because unfortunately since I installed the last module I have encountered a lot of instability:
- during the renewal of the IP from my provider which happens every 24 hours, sometimes the connectivity does not go back up (with any other version of the module it did not happen)
- sometimes the cell lock does not work and I am forced to reboot (even if I wait 10 minutes)
- I can only use the cell band using a workaround (it is necessary to select at least one N band, if I want to have the specific bands for me, if I do not do it, the cell band does not work)
Thanks a lot
also interested.
Tried power off modem about 3 minutes or more, not just a reboot?
2 -
yep, turned it off for one night, about 6 hours, but there were no substantial differences
Have same problem. How to downgrade?
i am trying to downgrade too. is there any way?
2 -
I am trying to downgrade also, is there any option for that? R13A04 basically killed all the connectivity for the modem.
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
