How do I switch wifi channels on the EX7710-B0 router?
There are multiple other wifi channels on the same channel causing interference and I wanted to change channels. When entering the default gateway IP into my browser and entering in the username and password, I get taken to "EX7710-B0 WAN service" which appears to be where I can change settings relating to the PPPoE user and password, IP addresses, and the VLAN ID. There's nothing here to indicate where I should be able to change the channels on the router and no other submenus. Is the router locked to a single channel or am I just missing something?
Hi Sir
I believe your EX7710 is a opensync-Plume model
The Wi-Fi channel of this model is controlled by the Plume cloud, and users are not able to change the Wi-Fi channel settings by themselves.
Technical Support Engineer
Technical Support Department I
ZyXEL Communications Corp.
Hi Sir
- 441 Beta Program
- 529 USG FLEX H Series
- 333 Security Ideas
- 51 Wireless Ideas
- 292 Service & License
- 461 News and Release
