NSA320s - Upgrading the SMB protocol support
kemes
kemes Posts: 11 image  Freshman Member
edited January 2023 in Personal Cloud Storage
Hi, I have an NSA320s. I've been a long time linux user and recently I discovered that in Ubuntu, which I'm mainly usin the SMB1.0 support was disabled in the latest kernels (I do understand why).
Is there a safe way to update the NSA320s firmware to support a newer SMB protocol?
Best Answers
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    I know of two options. You can install Debian on that NAS, with a newer smbd. More info here. Or you can install the Entware-ng smbd as drop-in replacement of the firmware smbd. More info on http://zyxel.diskstation.eu/forum/viewtopic.php?f=4&t=24. If you can't reach to zyxel.diskstation.eu, (DNS issues) you can use metarepository.tk, which is the same server.
    To install Entware-ng, first install MetaRepository. http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/
    If you need to use metarepository.tk, you'll have to edit the web_prefix file.
  • Mijzelf
    The firmware uses only stock Linux software raid and filesystems. So in Debian it's a matter of the rigjht configuration to get the disks assembled and mounted.
    Entware-ng runs next to the firmware, and by using the zyxel-samba-replacement package only smbd/nmbd is replaced. The firmware still mounts the filesystems and managed smb.conf.
  • Mijzelf
  • kemes
    Thank you Mijzef for this valuable and well composed info!
    In these options can I leave the existing storage disks as they are (I will backup before making changes)? In the case of using either Debian or Entware-ng, will they recognize the my current storage disks as they are now without the need of formating them?
  • Mijzelf
  • Milc
    Milc Posts: 3 image  Freshman Member
    edited November 2023
  • tonytogna
    tonytogna Posts: 18 image  Freshman Member
    @Mijzelf would You be so kind to help me find the 2 resources for updating Samba, they are no longer available, neither the forum post, nor the package. Many Thanks
  • AlexanderKuhnert
    AlexanderKuhnert Posts: 2 image  Freshman Member
    Hello, i need help. I installed the Repo and Entware-ng.
    But Samba 3.x is not available. How can i install it.
    I need a detailed Instruction for dummies please. :)
  • Mijzelf
    https://zyxel.ddnss.eu/forum/viewtopic.php?f=4&t=24
