Site/Network lost by Android app
Hi - while my network/site (or whatever this is called, can't see that right now) has been working for a LONG time and continues to work at the present time, the multy app has just lost it a few minutes ago. When I started the app, my devices where shown for a second or so, and then they disappeared.
The messages presented are:
"Verbindung getrennt", and:
"Stellen Sie die primäre MULTY-Verbindung erneut her,
um diesen Standort wieder aufzunehmen."
Which in english is about like this:
"No connected", and:
"Re-create the primary MULTY connection in order to re-connect with this site"
Yes I know support life for my Multy devices is over, but that doesn't mean that Zyxel can simply pull the plug and kill my network.
… has the server had a glitch that perhaps still needs resolving?
Thanks in advance for any help!
Regards
Werner
Hi @w8rn8r
Could you help to send a feedback in the Multy APP? This could help us investigate this issue.
Additionally, we will reply you via the feedback email.
Zyxel Melen0 -
Edited: proceeding further by selecting email for sharing, the email address was presented.
— Werner
Hi Melen,
the "Feedback" button leads me to a selection for sharing the information - how and where to should I send it, I suppose via email, to which email address?
Werner0 -
Hi @w8rn8r
We received your feedback email. We are checking it and will update you once we get further information.
Zyxel Melen0 -
Exactly the same happened here, but neither Android nor iOS is working.
Having exactly the same error messages but it was working before for more than a year now!
Yep, my network had also been working without any problems, for over a year.
Makes me wonder about where the problem was caused…
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 499 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
