Site/Network lost by Android app
w8rn8r
w8rn8r Posts: 28 image  Freshman Member
First Comment Seventh Anniversary
edited September 2025 in Multy WiFi System
Hi - while my network/site (or whatever this is called, can't see that right now) has been working for a LONG time and continues to work at the present time, the multy app has just lost it a few minutes ago. When I started the app, my devices where shown for a second or so, and then they disappeared.
The messages presented are:
"Verbindung getrennt", and:
"Stellen Sie die primäre MULTY-Verbindung erneut her,
um diesen Standort wieder aufzunehmen."
Which in english is about like this:
"No connected", and:
"Re-create the primary MULTY connection in order to re-connect with this site"
Yes I know support life for my Multy devices is over, but that doesn't mean that Zyxel can simply pull the plug and kill my network.
… has the server had a glitch that perhaps still needs resolving?
Thanks in advance for any help!
Regards
Werner
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @w8rn8r
    Could you help to send a feedback in the Multy APP? This could help us investigate this issue.
    Additionally, we will reply you via the feedback email.
    Untitled Image
    Zyxel Melen
  • w8rn8r
    Edited: proceeding further by selecting email for sharing, the email address was presented.
    — Werner
    Hi Melen,
    the "Feedback" button leads me to a selection for sharing the information - how and where to should I send it, I suppose via email, to which email address?
    Werner
  • Zyxel_Melen
    Hi @w8rn8r
    We received your feedback email. We are checking it and will update you once we get further information.
    Zyxel Melen
  • RonDev
    RonDev Posts: 3 image  Freshman Member
    Exactly the same happened here, but neither Android nor iOS is working.
    Having exactly the same error messages but it was working before for more than a year now!
  • w8rn8r
    Yep, my network had also been working without any problems, for over a year.
    Makes me wonder about where the problem was caused…
