USG FLEX 500H - Logs broken AGAIN
Hello, the logs on our 500H are broken again, even with the latest firmware 1.35(ABZH.2) as you can see in the following picture
There is also a previous question tha has already been answered by @Zyxel_Judy
V1.32 500H: the logs are broken — Zyxel Community
Logs and time seems fine here can you check in USG system > settings the time is correct to windows?
I also use windows as a time server for my USG
ConfigureNTP Server in Windows Server 2019/2022 | ComputingForGeeks
You will also need this set on the USG by SSH
edit running
vrf main ntp maxdistance 16
commit
copy running startup0 -
Seems fine here like I said time matches in real time
I suggest you test setting up windows as a NTP server and see if that makes difference?
I know that with these FLEX H they send logs to nebula maybe your not linking to the servers correctly and its causing a problem? I know that I'm in a case where the USG fail to connect to server sometimes.
Do you have many WAN IP uplinks?
I don't know why, but the logs feature is completely stopped on our device. I don't think it's a problem about NTP or wan config
No logs are sent to Nebula or SecuReporter either.
I know how to solve the situation: reboot the device as usual 😫
@Zyxel_Melen @Zyxel_Judy Would you like to investigate this issue? If not, I will have to reboot the device….
Hi @Mk88_it
PM sent. Please help to provide the org and site name and enable Zyxel support. Thanks!
Zyxel Melen0 -
One thing I'm doing different to most people is the following:
make group with the following FQDN
*.myzyxel.com
*.zyxel.comthen make a routeing rule
incoming Zywall
Destination Address FQDN group you made
nexp hop your WAN interface
SNAT none
then reboot see if that fixes it
I don't think this solution is relevant to the problem described.
Well it still the fact that I don't see this problem so must be doing something different if the USG is not connecting to Nebula maybe thats the reason why log locally are not happening in time.
I think it's something related to device insight function
well I do have that disabled so you might be right?
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
