Multy X WSQ50 Firmware
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,683 image  Zyxel Employee
    Sent.
    Zyxel Melen
  • OliverPayne
    OliverPayne Posts: 3 image  Freshman Member
    hi - I also have the same problem and need the Firmware update please
  • mschubert
    mschubert Posts: 10 image  Freshman Member
    Hello, could you also send me the firmware? I have the same problem.Many thanks
  • mschubert
    Hello @Zyxel_Judy, could you also send me the firmware? I have the same problem.Many thanks
  • mschubert
    Hello @Zyxel_Melen,
    could you also send me the Firmware? I have the same problem.
    Many thanks
  • mschubert
    I can't connect to the device. Reinstalling the app fails with a "Settings error."
    @ZyXEL_Melen Could you please send me the latest firmware?
  • OliverPayne
    I need the firmware update too please, I have the same issue.
  • Dgroenlund
    Dgroenlund Posts: 2 image  Freshman Member
    I need the firware update. Thank you.
  • Dimon12
    Dimon12 Posts: 2 image  Freshman Member
    I own a Zyxel Multy X (model WSQ50, EU region).
    Could you please provide me with the latest firmware V2.20(ABKJ.8)C0 and the update instructions?
    Thank you very much in advance!
  • SWITCH_USER
    SWITCH_USER Posts: 2 image  Freshman Member
    Hi!
    I mistankely downgraded both my Multy WSQ50 and WSQ20 using USB stick. Now both devices no more link to my account as they seem work almost correctly I am unsable to manage my network.
    Can pls somebody pls post both mentioned firmwares?
    The one I need for WSQ50 is V2.20(ABKJ.8)C0
    And the one for WSQ20 is also missing.
    Kindest regards
