I need the latest firmware and install instructions for WSQ50
Rozza
Rozza Posts: 1 image  Freshman Member
edited October 2025 in Multy WiFi System
Im having the same issue as others - the Multy app refuses to connect to the router, which I think is affecting my ability to add additional Multy X units.
Please can you send me the latest firmware for the WSQ50 and install instructions?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,535 image  Zyxel Employee
    Hi @Rozza
    File sent to you via private message!
    Zyxel Melen
  • Дмитро
    Дмитро Posts: 2 image  Freshman Member
    Hello Zyxel Support Team,
    I have a Zyxel Multy X (model WSQ50) that I cannot connect to the Multy app on iOS.
    I’ve read that a firmware update can fix this issue. Could you please provide me with
    the latest firmware file (.bin) for manual installation?
    Device details:
    Model: Multy X (WSQ50)
    Serial Number: [your serial number]
    Thank you in advance for your help.
    Best regards,
    Dmytro
