How to restoring NSA325 firmware?
SAFC
SAFC Posts: 1 image  Freshman Member
edited May 2019 in Personal Cloud Storage
Hi all, a have a nsa325 v2 with problem - abnormaly starting and not detect for lan interface. I think that the problem is in the firmware. How restoring it with USB flash or other way?
I have a usb-ttl for a PL2032 chip.
#NAS_May_2019
  • Mijzelf
    Mijzelf Posts: 3,049 image  Guru Member
    You can find a recovery stick here. Unzip the right zipfile to a FAT formatted USB stick, plug that in a back port of the NAS, and power it on. It should flash the firmware version mentioned in the zip filename, and poweroff the box. Remove the stick, and power it on again.
  • Gabor_D_1
    Gabor_D_1 Posts: 2 image  Freshman Member
    I have the same problem, but the link is no longer working. Please make the recovery tool available again. I want to update the firmware in recovery mode.
  • Gabor_D_1
    Thank you very much.
