5.41 FW update with delay
GiuseppeR
GiuseppeR Posts: 615 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
Hello everyone,
I tried to updated several firewall Flex series manually, but some of them failed.
As you can see here:
You can find an example where it seems that the last update was done at 21:15 (some minutes ago…) but the firmware version seems to be always the 5.40 instead of the 5.41
Very strange behaviour, because I saw that firewall rebooting so I thought 5.41 was done
Nebula Tips & Tricks
