5.41 FW update with delay
Hello everyone,
I tried to updated several firewall Flex series manually, but some of them failed.
As you can see here:
You can find an example where it seems that the last update was done at 21:15 (some minutes ago…) but the firmware version seems to be always the 5.40 instead of the 5.41
Very strange behaviour, because I saw that firewall rebooting so I thought 5.41 was done
Maybe the firmware failed and you went back to 5.40?
Is firmware type set to latest?
Hi @GiuseppeR
I tested firmware upgrade and successed. Could you enable zyxel support access so we can check the related logs?
Zyxel Melen0 -
Hi @Zyxel_Melen
sent details and access via PM
- 441 Beta Program
- 211 Nebula Ideas
- 542 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
