Bug in API
When i use port profiles, and i use the:
https://api.nebula.zyxel.com/v1/nebula/{siteId}/sw/{devId}/port-settings
I retrieve the default settings of the port. (so trunk pvid 1 etc). while many ports are disabeled and are access ports etc.
example:
type access in nebula, trunk with api.
when i set manually the settings, it's correctly (so without port profiles)
yours dennis
Hi @Dpj,
Sorry for the late reply!
After a thorough investigation, we have confirmed that this is a bug and we are actively working on a fix. The timeline for the resolution is currently estimated to be mid to late November.
We appreciate your patience :)
Zyxel Tina
Hi @Dpj,
Zyxel Tina
@Zyxel_Tina No problem! thank you for picking it up. Something else about the API. I would like to hear your thoughts about this.
Lately Zyxel added an functionality to the API. Creating organizations with the API. Great!, further creating sites, and adding devices to it. Sounds great, but to be honest, not really working the way i expected.
For who is the API important? in my opinion for the MSP's arround. So it's important to easily and quickly create organizations and adding devices and licenses to it. And the licenses is the Issue. Because i cannot add devices directly after creating organizations and sites.
So the step we have to do now, create organization and site through api, login the nebula site, search the new org, add licenses to it, then with the api add devices, in the portal attach the license to the new device. so that's not convienient.
I understand with an pro license, i have more options likte logging etc, but i think the MSP license should give us more power with the API and deploying organizations, sites, devices and licenses. At the moment creating organizations with the API is not very usefull.
An other options i was thinking of: when you create an organization, you can activate the trial for 30 days. (but this only becomes active when you add an device to it.) So if it is possible to activate this trial through the api, without adding an device to it. (so you have an pro organization). it would solve everything.
Yours Dennis
Hi @Dpj,
Thanks for your detailed feedback!
Regarding your request about the license API, we have created an idea post for you. We'll be monitoring the votes and comments as part of our evaluation process. This helps us when evaluating this feature. Once the evaluation is completed, we’ll update the status accordingly. Please don’t forget to give it a vote if you support this request.
Zyxel Tina
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
