[Important Announcement] End of FTP Service Support for Home NAS Series
I have the exact same issue:
~ $ echo "ftp://192.168.178.10" > /i-data/sysvol/admin/zypkg/web_prefix
-sh: can't create /i-data/sysvol/admin/zypkg/web_prefix: nonexistent directory
~ $ mkdir /i-data/sysvol/admin/zypkg/
mkdir: can't create directory '/i-data/sysvol/admin/zypkg/': No such file or dir ectoryChecking the folders, there is no "admin" folder in my sysvol folder. I would appreciate some help, NAS is model N540.
You could try with command : mkdir -p /i-data/sysvol/admin/zypkg before do the command:
echo "ftp://YOUR_NAS_IP" > /i-data/sysvol/admin/zypkg/web_prefix
OK - followed the instruction and all worked fine until the final App Center refresh
Is there a fix?
Buongiorno, io mi fermo al passaggio 3, dopo che creo la prima cartella non riesco a creare le altre 2 sotto cartella per caricare i file zippati.
Hat irgendwie alles funktioniert bis auf den letzten Punkt.
Alle Apps aktualisieten und es ist nichts passiert.
Die Meldung heißt: Ihre Apps sind auf dem aktuellem Stand.
Ist das normal?0 -
Hello, I get an error when I type the command and it is impossible for me to go any further. Do you have a solution please?
~ $ ftp://192.168.1.116 > /i-data/sysvol/admin/zypkg/web_prefix
-sh: can't create /i-data/sysvol/admin/zypkg/web_prefix: Permission denied0 -
Hi, I followed the procedure and it worked, but now Owncloud and
PHP-MySQL-phpMyAdmin don't work. Any solutions?0 -
I encountered a download list failure when trying to deploy the app download. The MyZyxelCloudAgent needs to be updated to the latest version for it to work properly. After upgrading to the latest firmware, it should work fine. As I recall, version 6 is for the NAS326, and version 7 is for the NAS540.
Hi @Emacap76
Puoi mappare il dispositivo come unità di rete su Windows e creare manualmente le cartelle lì. Se riscontri difficoltà in qualsiasi passaggio, non esitare a contattarci.
Hi @frontsys
The MyZyxelCloudAgent needs to be upgraded to the latest version. Please make sure you have downloaded and installed the latest NAS firmware.
- 439 Beta Program
- 2.8K Nebula
- 201 Nebula Ideas
- 6.3K Security
- 503 USG FLEX H Series
- 324 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 458 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
