[Important Announcement] End of FTP Service Support for Home NAS Series
  • LukeT
    LukeT Posts: 2 image  Freshman Member
    I have the exact same issue:
    ~ $ echo "ftp://192.168.178.10" > /i-data/sysvol/admin/zypkg/web_prefix
    -sh: can't create /i-data/sysvol/admin/zypkg/web_prefix: nonexistent directory
    ~ $ mkdir /i-data/sysvol/admin/zypkg/
    mkdir: can't create directory '/i-data/sysvol/admin/zypkg/': No such file or dir ectory
    Checking the folders, there is no "admin" folder in my sysvol folder. I would appreciate some help, NAS is model N540.
  • suisei
    suisei Posts: 120 image  Ally Member
    First Comment First Answer Friend Collector Second Anniversary
    You could try with command : mkdir -p /i-data/sysvol/admin/zypkg before do the command:
    echo "ftp://YOUR_NAS_IP" > /i-data/sysvol/admin/zypkg/web_prefix
  • frontsys
    frontsys Posts: 6 image  Freshman Member
    OK - followed the instruction and all worked fine until the final App Center refresh
    Is there a fix?
  • Emacap76
    Emacap76 Posts: 2 image  Freshman Member
    Buongiorno, io mi fermo al passaggio 3, dopo che creo la prima cartella non riesco a creare le altre 2 sotto cartella per caricare i file zippati.
  • Stefan_R
    Stefan_R Posts: 1 image  Freshman Member
    edited October 2025
    Hat irgendwie alles funktioniert bis auf den letzten Punkt.
    Alle Apps aktualisieten und es ist nichts passiert.
    Die Meldung heißt: Ihre Apps sind auf dem aktuellem Stand.
    Ist das normal?
  • wardevilpro
    wardevilpro Posts: 2 image  Freshman Member
    Hello, I get an error when I type the command and it is impossible for me to go any further. Do you have a solution please?
    ~ $ ftp://192.168.1.116 > /i-data/sysvol/admin/zypkg/web_prefix
    -sh: can't create /i-data/sysvol/admin/zypkg/web_prefix: Permission denied
  • Tonysa
    Tonysa Posts: 2 image  Freshman Member
    Hi, I followed the procedure and it worked, but now Owncloud and
    PHP-MySQL-phpMyAdmin don't work. Any solutions?
  • suisei
    I encountered a download list failure when trying to deploy the app download. The MyZyxelCloudAgent needs to be updated to the latest version for it to work properly. After upgrading to the latest firmware, it should work fine. As I recall, version 6 is for the NAS326, and version 7 is for the NAS540.
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    Hi @Emacap76
    Puoi mappare il dispositivo come unità di rete su Windows e creare manualmente le cartelle lì. Se riscontri difficoltà in qualsiasi passaggio, non esitare a contattarci.
  • Zyxel_Jerry
    Hi @frontsys
    The MyZyxelCloudAgent needs to be upgraded to the latest version. Please make sure you have downloaded and installed the latest NAS firmware.
