[Important Announcement] End of FTP Service Support for Home NAS Series
Hi @Stefan_R
Wenn Sie die Schritte befolgt haben und dieses Ergebnis erhalten, bedeutet das, dass Sie den Synchronisierungspfad erfolgreich aktualisiert haben.
Hi @wardevilpro
All of the commands must be run using the root account; other users may not have sufficient privileges.
Hi @Tonysa
If the service server has some enhancement and have done version upgraded, the existing package will no longer be compatible, and synchronization with the server will not be possible because the server has a new update.
Hi @Zyxel_Jerry
I was pretty sure I was running the latest NAS firmware, but I just checked and yes, I am running the latest. Tried to refresh the App list again and the same result - Download List Failed - any other ideas?FYI
Model Name
NAS326
Current firmware version
V5.21(AAZF.18)
Last Check2025/11/04 15:03:04
Hi @frontsys
As I see the attache screenshot provided.
The myZyXELcloud-Agent version is not on the latest, after put the package into the correct synchronize path, then it should able to work.
Please follow the steps refer to the article below to complete the synchronization.
https://community.zyxel.com/en/discussion/29667/important-announcement-end-of-ftp-service-support-for-home-nas-series/p10 -
I tried to sync the path but it came up with an error saying no devices found.
I went to the ZyxelCloud and unpaired the device, now I cannot pair my NAS326 - it asks to press the pair button within 10 minutes but after about 12 seconds it says Device Not Found, even when I press the pair button.
I cannot fix this.
- 439 Beta Program
- 2.8K Nebula
- 201 Nebula Ideas
- 6.3K Security
- 502 USG FLEX H Series
- 324 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 458 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
