MAC Filter whitelist on Access Points
This morning I was at a client and I had to create wireless network on sensitive network unfortunately(no cable possible). Created decent password and only allowed 1 AP to send out, but in the early days I used to work with a MAC Filter list where I could work with whitelisting. I don't seem to find this on Nebula anymore except for Captive portal? But this won't work as the client is an old Win2000 machine (no internet access on the SSID of course, only intranet)
Still possible or not?
Hi @nielsscheldeman,
Nebula does not have a “MAC Filter list”. However, to fulfill your requirement of allowing only specific devices to connect to a particular SSID, Nebula supports a MAC-based Authentication feature that provides similar control.
You can refer to this FAQ for detailed setup instructions.
Zyxel Tina
Zyxel Tina
Thank you, I think this will work for me indeed.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
