NR5101
Janlar
Janlar Posts: 3 image  Freshman Member
It says "Sim Card Not Detected" when I log in, so it doesen't work.
It has worked for 3 years.
Things I tested:
Reboot
Testen different simcard
Tested different simcard with other provider
Reset
Uploaded firmwere again
Uploaded modemfirmwere again
Still says "Sim Card Not Detected"
Is it "over and out"?
Mvh Jan
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,544 image  Zyxel Employee
    Hi @Janlar
    Based on the test you did, it seems like a hardware issue. Please contact the seller or the provider for help with the RMA.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Janlar
    Zyxel Melen
  • Janlar
    edited December 2025
    Ok thanks….Can I make the 5101 to work in Bridge mode….can't find that in settings ?
    I'v bought the FWA505 and would want that to work with the 5101 that WiFi still works on and its too old for RMA i think (3 1/2 year)…
    Mvh Jan
  • Zyxel_Melen
    Hi @Janlar
    You can make it works like in bridge mode for its LAN and WiFi/SSID.
    Here is what you need to do/check:
    1. Please ensure your firmware is V1.16(ACCG.1)C0 or V1.00(ABVC.8)C0
    2. Disable the NAT & IGMP Proxy & Apply as Default Gateway settings for the Ethernet WAN interface.
      Path: Menu > Broadband > ETHWAN > modify/edit button > Routing Feature image.png
    With this configuration and connect the ETHWAN to my uplink device, I can get the IP address from the uplink device.
    Additionally, please remember to configure different management IP address for FWA505 and NR5101. Using same IP address will cause issues since IP conflict.
    Hope this helps.
    Zyxel Melen
