Mysterious FWA710 DownGrade FirmWare
Luca_G
Luca_G Posts: 5 image  Freshman Member
I noticed something mysterious and disturbing about my Zyxel FWA710: I found the old FW V1.20 installed when I upgraded to V1.60 a few weeks ago!!!
Well... I also searched the Nebula Cloud services to see if there was something that for some reason had automatically installed 1.20, but I didn't find anything.
Has anyone ever experienced something similar?
  • Daniel_505
    Daniel_505 Posts: 4 image  Freshman Member
    My FWA505 was downgraded from v1.60 to v1.19 because the first release of v1.60 was bugged.
    Later, a patched version (v1.60(ACKO.2)) was released and I was able to upgrade again.
    You should check on Nebula Cloud if a newer firmware version is available for your FWA710.
  • Luca_G
    mmmhhhh I'm not sure this is the rational: the last version is always the FW Version "FWA710 V1.60(ACGC.1)C0". If there is a problem with this version, remove it from the downloadable versions. I installed it again, let's see what happens.
    However thanks for the information, it seems to exist a services that downgrade the firmware if necessary.
    Ciao, Luca
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,259 image  Zyxel Employee
    Hi @Luca_G
    Could you help to enable Zyxel support access so we can help to check?
    FWA710 doesn't encounter the issue that @Daniel_505 mentioned, so the firmware of FWA710 should not be scheduled for previous firmware.
    Zyxel Melen
  • Luca_G
    Only a Question: I use the FWA710 to Work, it's absolutely important not to have disservices during your checking. is that so?
  • Zyxel_Melen
    Hi @Luca_G
    It won't have disservices during the checking since we only check the logs.
    Zyxel Melen
  • Luca_G
    Done one hour ago. I don't see update, also after reconnecting!
