Elite Pack Trial
loizospro
loizospro Posts: 2 image  Freshman Member
I have activated an Elite Pack trial and when i try to assign this trial license to my USG LITE 60AX it gives me an error that there are no available licenses for this device?
Can someone explain why?
Thx
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,683 image  Zyxel Employee
    Hi @loizospro
    Could you help:
    1. Record the error by using browser plugin Jam.
    2. Enable Zyxel support access for this organization and provide the license key for us to check.
    Zyxel Melen
  • Zyxel_Melen
    Hi @loizospro
    We noticed you create a ticket to us.
    From what we can see, you've successfully activated the trial mode within the Nebula Control Center (NCC). When you activate a trial like this, the system doesn't generate a separate license key for you to manually assign. Instead, it automatically applies the Elite Pack features to all eligible devices associated with your organization that are logged into the NCC.
    You should be able to verify that the Elite Pack features are now active for your USG LITE 60AX by navigating to the "Configure" section for the device in NCC. There, you should see the Elite Pack features available for setup and use.
    Please let us know if you're able to confirm this, or if you have any further questions. We're here to help!
    Zyxel Melen
Service & License Help Center
