Status rings disappeared
saltet
saltet Posts: 76 image  Ally Member
I have recently seen that the status rings for ap diassppead in Nebula - see screen shot
Now is it only for the root ap -full green but the remaning ap,s have lost its rings for status which I previously had.
Is this a change in Nebula?
The network works fine but is the change you have made in Nebula upgrade of software
Best Answers
  • Zulgrib
    Zulgrib Posts: 48 image  Freshman Member
    First Answer First Comment Friend Collector Fifth Anniversary
    I recommend you don't share your email address in public forums. If you used the same email to authenticate on the forums, Zyxel staff can probably see the email address.
  • Zyxel_Tina
    Zyxel_Tina Posts: 723 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @saltet,
    Regarding the issue with status rings missing on APs in Nebula, we have addressed this issue. This will be fixed in Nebula release v19.30, scheduled 2026/01/19. Please stay tuned to our News & Release section when the firmware becomes available.
    We appreciate your understanding and patience!
    Zyxel Tina
  • Zyxel_Tina
    Hi @saltet,
    We've noticed similar problems and are actively investigating them.
    To help us confirm if this is the same problem and troubleshoot further, could you please enable Zyxel Support Access? This will allow our team to review it directly.
    Thank you for your cooperation!
    Zyxel Tina
  • saltet
    edited December 2025
    You have access to my account.
    I have two org The same problem with both
    and thanks for you quick reply
  • Zulgrib
  • Zyxel_Tina
    Hi @saltet,
    Thank you for the update! We'll inform you of any updates after our investigation.
    We appreciate your cooperation and patience. Happy New Year ~
    (For privacy, we've removed your email address from public view.)
    Zyxel Tina
  • saltet
    Good Point but when asked to open my account for investigation I don’t know how to do reply what account to look into.
  • Zyxel_Tina
    Hi @saltet,
    Zyxel Tina
Nebula Tips & Tricks
