ZYXEL WSR30
Djordje
Hello, I bought 3 Zyxel MULTY U WSR30 devices to extend my Wi-Fi network. From the very beginning, I have had a problem with the Mylti app, which stops the installation of the device at the end and shows that it is disconnected when I try to run it, even though the WSR30 created a network on the main unit. I was not able to connect the other devices because the app is disconnected. Aplication version is 2.6.4.250701. Please help me.
Hi @Djordje
This is more likely the device is using old certificate. Let me send you a private message to schedule a remote with you to upgrade the certificate.
Zyxel Melen0 -
Hi, can you help me to? I have exact same problem.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
