NR7302 ethernet connection interupts under heavy VPN loads
jesperwj
jesperwj Posts: 2 image  Freshman Member
edited June 2025 in Mobile Broadband
Good morning.
I’m having some issues with my NR7302 Outdoor router, where when some systems on the network are using a VPN and doing large file transfers the ethernet interface gets marked as down. In all other cases, such as under other heavy loads this is not the case.
The modem is connected to a router running OPNsense, through the provided cables and PoE injector. The modem is configured in IP Passthrough mode, and is running firmware version 1.00(ACHA.4)b5_F0.
Here is an excerpt from the log on the modem:
Timestamp
Level
Process
Message
Jun 26 08:29:10
info
cellwan
CM_SYSLOG: beCellIntfNsaConfigStatsUpdate; (Index: 1) Band: NR5G_N78, PhyCellID: 212, RSRP: -93, DL_BW: 60
Jun 26 08:29:10
info
cellwan
CM_SYSLOG: beCellIntfConfigStatsUpdate; Name: rmnet_data0, CurrentBand: LTE_BC7, CellID: 59952654, PhyCellID: 363, RSRP: -94, UL_BW: 20, DL_BW: 20
Jun 26 08:28:55
info
cellwan
Jun 26 08:28:55
info
cellwan
Jun 26 08:28:54
info
httpd
zHttpd: Account: User <REDACTED_USER> login from host CLIENT_IP.
Jun 26 08:28:41
debug
dhcpd
dnsmasq-dhcp: sendLeaseMessageToESMD esmd ret=1
Jun 26 08:28:41
debug
dhcpd
dnsmasq-dhcp: sendLeaseMessageToESMD send to esmd buf = {"ac":"add","expire":"86765","mac":"DEVICE_MAC","ip":"CLIENT_IP",…,"cid":"01:DEVICE_MAC","ifname":"bridge0"}
Jun 26 08:28:41
info
dhcpd
Jun 26 08:28:33
info
cellwan
CM_SYSLOG: beCellIntfConfigStatsUpdate; Name: rmnet_data1, CurrentBand: LTE_BC7, CellID: 59952654, PhyCellID: 363, RSRP: -94, UL_BW: 20, DL_BW: 20
Jun 26 08:28:33
notice
esmd
esmd: Interface: eth0, Status: Up, Speed: 2500, DuplexMode: Full
Jun 26 08:28:29
err
dhcpd
dnsmasq-dhcp: failed to read /etc/ethers: No such file or directory
Jun 26 08:28:29
info
dhcpd
dnsmasq-dhcp: DHCP, IP range CLIENT_IP - CLIENT_IP, lease time 1d
Jun 26 08:28:28
notice
esmd
esmd: Interface: eth0, Status: Down
Jun 26 08:28:17
debug
dhcpd
Jun 26 08:28:17
debug
dhcpd
dnsmasq-dhcp: sendLeaseMessageToESMD send to esmd buf = {"ac":"add","expire":"86741","mac":"DEVICE_MAC","ip":"CLIENT_IP",…,"cid":"01:DEVICE_MAC","ifname":"bridge0"}
Jun 26 08:28:17
info
dhcpd
I have tried a lot of different combinations of settings, both on the OPNsense router and the modem, to no avail. I wouldn’t consider the configuration to be particularly exotic, so I was somewhat surprised that I couldn’t find any mention of similar issues on this forum or otherwise.
I would appreciate any and all help on this. If there is any information that is missing in my post I would be more than happy to provide it.
  • Zyxel_Brandon
    Zyxel_Brandon Posts: 27 image  Freshman Member
    First Answer First Comment
    Hi jesperwj,
    Firmware 1.00(ACHA.4)b5_F0 is a customized release for Deutsche Telekom. If you experience any issues with the NR7302, please reach out to Deutsche Telekom.
    Thanks.
  • jesperwj
    Hello Brandon,
    Thank you for your response.
    I purchased the Zyxel NR7302 directly from the Zyxel Amazon store, and I am located in Italy using a WindTre SIM. For that reason, I was a bit surprised to learn that the installed firmware was a Deutsche Telekom customized version. If that is the standard firmware shipped with units sold through Amazon, I appreciate the clarification.
    In any case, a firmware update released about a month after my original post appears to have resolved the issue. I simply forgot to follow up and confirm that the problem is no longer occurring.
    Thank you again for your assistance.
    Best regards,
    Jesper W.J.
