FWA515 Wireguard VPN Configuration
Hi.
I've migrated to FWA515 device from a Fritzbox. On the fritzbox I could set up a Wireguard VPN from a configuration file created from my Windscribe account.
I don't see any config settings like this on the FWA515 settings in either Nebula or the device settings or the remote msnagrment. Where in Nebula or on the device settings do I configure a VPN?
I think none of Zyxel products support Wireguard VPN as a server or client also the FWA515 has no VPN server or client option.
Thanks for reply. Sheesh that's not good news. I've just spent a small fortune on this device & it doesn't support basic VPN support that's available on the device it's replacing. There's also a subscription which isn't described anywhere before you purchase but pops up when you go to configure it.
Hi @m0p0h,
Thank you for your feedback. To clarify your concerns:
- VPN Capabilities: The FWA515 is primarily designed as a 5G mobile router that supports IP Passthrough to allow VPN traffic through. However, it does not feature built-in VPN Client/Server capabilities (such as WireGuard or OpenVPN). Currently, Tailscale VPN (a third-party VPN service built on the WireGuard protocol) is supported on our USG FLEX H-series firewalls.
- Subscription Inquiry: Regarding the subscription you mentioned, could you please provide the name of the service and a screenshot where it appeared? This will help us identify the problem and assist you further.
Zyxel Tina
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
