Multy X WSQ50 Firmware
13»
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,683 image  Zyxel Employee
    Hi @SWITCH_USER
    Please check the private message. I have send the guide to you. The firmware download link is in the guide.
    Zyxel Melen
  • Juggler
    Juggler Posts: 4 image  Freshman Member
    Having connectivity and stability issue as well. Tried different treatments and methods. Bridge mode for the last cure. Would like to install latest firmware in case it helps to improve usage and performance of the device. Device Multy X with firmware V2.20 ABND.9 C0. Would you mind to send newer version of firmware. Thanks.
  • Sergey_11289
    Sergey_11289 Posts: 3 image  Freshman Member
    I have a Zyxel Multy X router (model WSQ50, EU region).
    Could you provide me with the latest firmware version V2.20(ABKJ.8)C0 for USB download (containing .bin, .files, and .sha512 files)?
    Thank you very much in advance!
