SCR50AXE V1.30(ACGN.0) - Misalignment in traffic counters
Hello everyone,
as you can see it seems that today the security router processed about 6 gigs of traffic but not all counters are up to date:
On Nebula webUI you have the same values in the widget "Security router network applications":
How can I solve that?
This morning the widget of this pharmacy is empty:
while on the Nebula App it is hidden
Hi @GiuseppeR,
Could you please enable Zyxel Support Access and provide us your org/site names?
Zyxel Tina
Hi @Zyxel_Tina
I sent you a PM with details
Hi @GiuseppeR,
Regarding the issue you've encountered, please let me first clarify that the Threat Management statistics match WAN Usage.
Additionally, when Application Usage shows "no data," this is because some static IP addresses aren't recorded in Application Usage statistics.
Therefore, would you be willing to test this issue with the V1.30 DF firmware?
Zyxel Tina
Hi @Zyxel_Tina
how could be possible that some static IPs' traffic values are NOT recorded in a security router?
Is it possible that it misses the traffic going outside?
Right now the widget is like that:
But I miss these gigs:
Hi @GiuseppeR,
Thank you for your feedback!
The empty Application Usage data occurs because it collects statistics differently from Threat Management. Static IP clients may not be recorded, leading to empty entries.
Would you like to try the V1.30 DF firmware to address this? If so, we can build a DF based on V1.30 specifically for your testing.
Zyxel Tina
Hi @Zyxel_Tina
yes please, we can try that custom firmware.
Do you need to access all of my other ORGs with SCR50AXEs that are working properly?
Hi @GiuseppeR,
Sorry for the late reply! Our team is still preparing the firmware, and I'll inform you as soon as I have any updates. Regarding your question, we only need access to the affected org/sites currently.
Thank you for your patience and cooperation!
Zyxel Tina
Hi @GiuseppeR ,
Please check your Community inbox to discuss the scheduled date for the firmware update.
Zyxel_Judy
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
