[NWA130BE] Since 7.20, iPhone 16 toggles between WiFi and Celluar
I have not seen "my" issue now in three weeks.
I should not have written that. 😀
Yesterday, it popped up again. Once the AP was restarted, I noticed that I have ping drops for everything leaving that AP. Pinging the AP itself was fine. I remember that I had this before as well. So I checked the the interface errors on the (backbone) switch and it turns out there is some kind of issue with that specific AP. Reducing the link speed to 1000M / Gigabit helped, so this was a clear indication of a faulty cable. I replaced the patch cable and interface errors look good now.
I can imagine that my issues with my iphone can be explained by that. Especially, because my issues were always observed with that specific AP.
I will continue to update here.0 -
Hi @Flachzange
Thank you for your continued patience and for keeping us updated on this matter.
Our engineering team has conducted comprehensive testing and identified the connectivity issue between the iPhone 16 and NWA130BE. Our investigation reveals that the iPhone 16 is not properly responding to certain access point information frames, which subsequently causes the WiFi connection to be disconnected.
Please note that this is an ongoing investigation. While we have identified the technical behavior, our team is actively working to determine the optimal solution. We are committed to resolving this issue and will provide updates as soon as we have conclusive findings.
Recommended Temporary Workaround:In the meantime, we kindly ask you to try the following configuration change:
- Navigate to your SSID settings
- Adjust the band selection to 2.4GHz and 5GHz only
- Disable/unselect the 6GHz band
This configuration adjustment should provide stable connectivity while we work on a permanent resolution.
We appreciate your cooperation and understanding. Should you have any questions or require further assistance, please don't hesitate to reach out.
Zyxel Melen1 -
Thanks @Zyxel_Melen for the update. I can indeed confirm that non of my previous resolution attempts helped. It still occured during the last days. I will now disable 6 GHz to see if that improves the situation.
Same situation here… 2 nwa130BE unit and a iPhone 16 Pro Max with flickering WLAN<>5G.
Disabling the 6Ghz band, is a temporary solution.
I hope for a update.0 -
As the issue is acknowledged, I am sure Zyxel is already working on a fix.
And yes, disabling 6 GHz is not a solution ;)1 -
Same problem with my setup (3 WBE660S and 2 WBE630s) and IPhone 16 Pro Max.
Seems to be a specific problem with IPhone 16 devices.
When will this issue be resolved?0 -
Let me provide you a date code firmware download link via private message.
Zyxel Melen0 -
Thanks @Zyxel_Melen. Firmware is now installed on 4 APs and I will test. Feedback might take some time due to personal absences.
Hello, I also have problems with the iPhone 16Pro max. I could also test it if desired. 1x NWA130BE and 3x NWA50AX
Hi @benzfreak
Recording to our engineer, this issue should not occur on NWA50AX. Could you upgrade NWA130BE and monitor first? If still happens, please help to:
- Collect the diagnostic file for 4 APs.
- Record the issue timestamp.
- Record the issue device's MAC address.
Diagnostic file collect: Standalone mode / Nebula mode
Zyxel Melen0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
