Cloud saving mode activated after less than 30 days.
Hi!
My Nebula Cloud saving mode is activated again and again despide regulary admin logins on the same organization.
For example (logins):
2026-04-03 20:xx:xx «— Cloud saving active.
2026-03-21 22:11:55
2026-03-13 11:46:01
2026-03-12 16:16:24
They say it's only activated 30 days after the last admin login to an organization.
So, looks odd to me. Any idea how to fix this?
Hi @ViktorLima
We are clarifying this issue and I will update you once we have further information. During the waiting period, may I confirm that you did have access to the organization(like the dashboard of your site), did you not?
Zyxel Melen0 -
Hi @ViktorLima
Could you help to enable Zyxel support access so we can check this issue further?
Here is an FAQ for you to reference:
Zyxel Melen0 -
done
I am having this same issue …just happened again this morning and I log in very regularly. This is annoying.
In specific condition, the login log was incorrectly recorded. This issue is under fixing. I will update you once the fix is online.
Zyxel Melen0 -
We have fixed this issue, please help to access your org again, this action allows to renew the timestamp.
Zyxel Melen0
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
