v1.38 Dashboard Issues
MCFH
MCFH Posts: 26
First Answer First Comment Friend Collector Eighth Anniversary
image  Freshman Member
So I load my dashboard and get this error (I have cleared Edge's cache too)
This is being caused by the client usage widget
Error
Failed to load interface list
Error Code: (500)
/api/show/gui/widget/client/usage
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,751
    image  Zyxel Employee
    Hi users,
    Firmware version 1.39P0 is planned for release in July.
    Note: The error message appearing on the GUI of H Series devices only occurs in certain scenarios and does not affect all devices. If you are experiencing this issue, please share your device model name and we will provide the appropriate weekly firmware fix for you.
    Zyxel_Judy
«1345
  • Zyxel_Judy
    Hi @MCFH ,
    To better assist you, please provide the Nebula organization & site name and enable Zyxel support for our checking.
    Zyxel_Judy
  • MCFH
    MCFH Posts: 26
    Hi
    I have shared privately
  • SSC
    SSC Posts: 2
    I have the same problem. So if a solution exists. I will appreciate having it.
    BR
  • GiuseppeR
    GiuseppeR Posts: 778
    image  Guru Member
    Hi @MCFH and @SSC
    do you get this error with local access or remote access triggered from Nebula?
  • MCFH
    MCFH Posts: 26
    Local access
  • YanShadowGT
    YanShadowGT Posts: 23
    Hi, I have the same problem
  • Albe
    Albe Posts: 4
    Zyxel Certified Network Engineer Level 1 - Nebula First Comment Fourth Anniversary
    Alberto
  • Zyxel_Judy
    Hi Users,
    We are currently looking into this and will keep you updated as soon as we have any findings.
    Zyxel_Judy
  • Asgatlat
    Asgatlat Posts: 135
    image  Ally Member
    any news ?
    not want to apply 1.38 FW in production with this bug 😕
  • JakobH
    JakobH Posts: 4
    I get the same error on USG FLEX 50HP, running 1.38. Tested 3 browsers, Firefox, Edge & Chrome, all with the same result.
    Anyone running 1.38, whitout this error?
