NAS 326 findme does not work
rschoner
rschoner Posts: 4 image  Freshman Member
edited April 2018 in Personal Cloud Storage
New NAS326. Power light, system light and hard drive lights all solid white. LAN light blinking green. The router has seen the NAS326 and assigned an IP Address to it. I can access the NAS326 by using the IP Address. But when I try to use "Find Me" I push the button and nothing happens. I have tried holding the button until it beeps still nothing. I reset the system still nothing. I notice the button I push to "Find Me" is not lit, should it be? I have a working internet connection. Any ideas before I return it?
Thanks, Bob S
#NAS_April
  • rschoner
    Hi Again,
    I retried with Internet Explorer instead of Firefox and it found me.
    Thanks,
    Bob
«134
  • rschoner
    Hi Again,
    Thanks,
    Bob
  • Wiasouda
    Wiasouda Posts: 156 image  Master Member
    edited April 2018
    Findme is one of way to find the NAS326 and your PC/NB/Mobile should in the same subnet with NAS to make the findme work, but if there is another device in front of your router and make the network as 2 subnet, then I think this feature would not be work normally.
    Due now you can access the NAS326 via IP address, I think the NAS can workt normally.
    You can try more to check if the NAS326 still abnormal, then you return it.
  • ibo
    ibo Posts: 4 image  Freshman Member
    Hi there,
    i have th same problem as described by rschone.
    The router has seen the NAS326 and assigned an IP Address to it. I can access the NAS326 by using the IP Address. But when I try to use "Find Me" I push the button and nothing happens. I have tried holding the button until it beeps still nothing. I reset the system still nothing. I notice the button I push to "Find Me" is not lit, should it be? I have a working internet connection. Any ideas?
    macosX 10.11.6
    Firefox 60 / Safari 11.0.3 / Chrome  66.
  • Ijnrsi
    Ijnrsi Posts: 254 image  Master Member
    Findme is a way to help people reach access their NAS through LAN, if you want to access your NAS over internet, then you need to configure the port forwarding on your router or use myzxelcloud feature: https://mycloud.zyxel.com/help
  • ibo
    Neither the cloud is working. I can't pair the device...
    i can access only  through int.explorer...  :/
  • Ijnrsi
    Did you check your router support UPnP or not? And your NAS should place under main router's LAN, the topology should be like this: Internet-----PPPoE-----router-------NAS326
    Besides, you can also check if Myzyxelcloud in NAS web manage page was already paired, then you can unpair it in the page.
    If your router doesn't support UPnP, then you can use port forwarding to let you access NAS over Internet.
  • ibo
    UPnP i think its OK.
    ...and  from Zyxel control panel
    --About topology... I really don't know! :|
    maybe you're referring to this...
    an about myZxelCloud... we have totally different page.
    1. The email address is not linked.
    2.  the unpair button is greyed out.
    3. there's a message "To activate cloud functions..."
    But ZyxelCloud agent is installed...
    nothing's paired....
    and i cant pair neither manually...
    Thank you in advance!
  • Zyxel_Brian
    Zyxel_Brian Posts: 41 image  Zyxel Employee
    Hi @ibo,
    Already sent you a private message, please check your message box.
    Thanks.
    BRs,
    Brian.
  • JojjeGee
    JojjeGee Posts: 5 image  Freshman Member
    I've got the exact same problem. Tried to restart the cloud service by unpairing but now I can't pair it again. Upnp and all.
  • Zyxel_Brian
    Already sent you by private message for more detail information.
    Please check you message box.
    Thanks.
    BRs,
    Brian.
