How to load the drives of NAS325 into NAS326?
GaryHsu
I had a NAS325 but got no work last week. Then I buy one new NAS326 (since NAS325 is EOL) and move the drives from NAS325 to NAS326. But NAS326 can not recognize the drives, how can I do for this case?
And I also can not connect to NAS326 through web, is it normal? (I can see the NAS326 by NAS starter utility but nothing can do further.)
#NAS_June
#NAS_June
Unfortunately the disk layout of firmware 4 and lower is no longer supported/recognized by firmware 5 devices.
If you had a raid1 array, it's possible to do a poor man's conversion. Put one disk in the 326, and create a single disk raid1 volume. Then plugin the second disk, enable the ssh daemon, login over ssh, and assemble the (degraded) array on the second disk manually, and mount it. Then copy the contents of the old volume to the new volume. And finally add the 2nd disk to the new volume.
This involves copying all your data twice, and so it's time consuming.
- 588 USG FLEX H Series
- 476 News and Release
