NAS326 changing shares gives "unexpected error"
Hmm, I guest you login with admin. but without escalated your privilege to root.
Try #su and enter the admin's password again, then you may be able to do block copy.
Or you can create a new to folder and a subfolder it, and move all data to this foler, then you can directly copy it all to your external storange.0 -
Just looked at my twonkyserver.ini and see that
httpport= (nothing)
Allegedly the Media Server is enabled, 192.168.1.80:9001 (according to GUI)
but when I change any Media Server | Share Publish I'm back to the dreaded "Unexpected Error"0 -
IUsing your Telnet Trick I managed to find where the "disappeared" files were saved, and have moved them using the "File Manager | Drag | Move" option, but I need to perform teh Drag / Move twice for each folder. Is this by design or just a "Funny" on my NAS?0
Using your Telnet advice
httpport= (nothing)
That is really weird as the ini file still keep the wrong setting after you reset...
Maybe you can try to reset it via command: /usr/local/btn/reset_and_reboot.sh, then check again the ini file.
And you could try to export the ini file and modify the httpport to 9001 as below and import back to NAS, then the twonky page might be available.
Thanks Ijnrsi
Excuse the ignorance, but how do I export/import the INI file?
Secondly, if I try your suggestion "/usr/local/btn/reset_and_reboot.sh", this will not affect any of the data on NAS, unlike when I did a system reset & lost all my data0 -
The file you can export by using winscp or sftp login with root.
For the command, it is the same behavior as HW reset button, so the data should not be effected, but just the folder you created will be disable automatically, then you have to enable them manually.0 -
Hi Ijnrsi
Couldn't get WINscp to work.
In the end I used cp to copy twonkyserver.ini to a shared folder I could access, edited it using a windows editor & then copied it back again.
Restarted the NAS and at the moment the Twonky Media Service does work, and all my videos are visible under the TwonkServer icon in windows 10.
Hopefully that will remain the situation, thanks for your help1 -
Hi duggleb,
Congratulations, it works now.
I think you can keep the configuration file download, then if any issue occuring after you changed the config, then restore the configuration file back to NAS.0
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 320 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 399 News and Release
- 86 Security Advisories
- 3.8K FAQ
- 78 Security Highlight
