NSA325v2 doesn't work
2»
  • Mijzelf
    Mijzelf Posts: 3,049 image  Guru Member
    Can i recover this?
    Maybe. Depends on why the Debian install failed. You'll need to hook up a serial cable to find out. That should be a 3.3V TTL cable. The easiest way is an USB 3.3V TTL cable like this, but I know also of people who used the serial port of their Raspberry Pi. Anyway, only connect GND,TX and RX. Not Vcc.
  • Saani
    Saani Posts: 10 image  Freshman Member
    Thank you for your help. I think i have this cable, or similar, i buyed it for playing with android boxes. I'll try tomorrow and will reply.
  • Saani
    edited November 2018
    Hello. Now i have connected NSA via serial to my Raspbian (in the VM) and tryed to install Debian like here https://web.archive.org/web/20180423050001/http://zyxel.nas-central.org:80/wiki/Debian_on_325
    But at end i become a message "Bad Magic Number", NSA is no booting from the USB.
  • Mijzelf
    Can you provide a full bootlog?
  • Saani
    Hmmm, how can i mark and copy a whole bootlog (using "screen"? Because i can only see last 15 rows.(I managed to boot the original firmware, am not sure how)
  • Mijzelf
    Don't know. Doesn't your terminal emulator have a log option?
