Remote Access NAS326
Bernardo
Hi guys,
I have a NAS326 and unfortunately I still can not access remotely (for now I only log in locally)
and also during setup on myZyxelCloud I can not set up the uPnP.
So i wanted to know what ports I need to open.
(from remote I can access only through the app zyxelDrive but I'm interested in being able to access through the finder on the mac)
Could someone help me?
Thank you so much!
#NAS_Jan_2019
Check your gateway and DNS address in your NAS326 and myzyxelcloud package installed or not.
it should automatically show in the list, if no, then might be NAS326 can't access Internet.0 -
yes, I have these things but how can I access them remotely?
so you already pair the device to your cloud account?
If yes, you will see the UPnP setting in the cloud web site, then you can configure it and show the used port.0 -
Yes but when I try to click configure uPnP I get written "device not found" (as also in the image above)
I have also enabled the uPnP on my router but I can not synchronize the NAS with the router.
Maybe I have to forward a port on the router?
Normally, you doesn't need to setup the port forwarding.
Can you show the TCP/IP setting and UPnP page of your NAS here for checking?
Besides you could manually configure it in UPnP mapping page, try this.0 -
Now I'm not at home but the TCP / IP page shows this:
it's an image taken from the internet but instead of 10.168.3.134 I have my IP address 192.168.xx.xx and the subnet mask.
Unfortunately in the page "uPnP mapping" I get written that the router does not support uPnP so I can not see anything on this page, but I have enabled uPnP on the router ...
Is there anyone who knows the problem?
Have you manually setup static address for your NAS326? IP, DNS and gateway, then you can manually modify the UPnP port in UPnP port Mapping page.
And to unregister the device and reinstall the myzyxelcloud package, then do again the pair program.
Moreover, your NAS326 should find the UPnP router and show in this page.
Yes, I set a static I address on the router page, then on the ZyXELCloud page I managed to give the DDNS a name and then the Gateway came out. The DNS on the modem is not set but I do not know what to put, because among the various items there is a box where it makes me choose for example: "No-ip" or other services.
Thanks a lot!
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 320 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 398 News and Release
- 86 Security Advisories
- 3.7K FAQ
- 78 Security Highlight
