Remote Access NAS326
What is the result in your NAS in this page?
What did you set in router and NAS TCP/IP generial settings and Network Interface?
Can you post the screen here to check?
Normarlly, NAS can access internet and package installed, then it should be able to show in the list in zyxelcloud page and also router support UPnP, then able to control UPnP setting in zyxelcloud page.
These are my screens:
The second photo already told you the NAS doesn't find the UPnP router, you might need to check your UPnP setting.
If you still have problem with UPnP, that you only can setup port forwarding on your router.0 -
I tried but I can not ... which port should I open?(however, through the app zyxelDrive I can access even remotely so the problem is only via pc or finder from the mac)0
for web port default is 80, but it might be collided to your router, so you can set 8080 and change your NAS http port from 80 to 8080 as your fourth photo.
But don't know what service you wuold like to use, but they should use the default port.as ftp port 21, ssh port 22 and telnet port 23 etc...0 -
This is the screen where I configured port 21:
There are some solution?0
... I had similar problem. I have a 4G router and DNS settings were from 192.168.8.100 to 192.168.8.200. My NAS326 address was 192.168.8.240 and UPnP did not work. When I change the address for ...200, then it was okay. Just in case, check DNS settings in router.0
Ok so I had problems with the UPnP in the beginning also. I solved it like this:
IN THE ROUTER:
It seems that Zyxel NAS version of UPnP must match that of the Router UPnP version in order for it to "detect a UPnP router". What you must do is to:- Log in to your router as admin
- Find UPnP settings (if you know your router supports UPnP)
- See if you can change UPnP Datamodel version from 2 to 1
IN THE ZYXEL NAS:- Start Control Panel
- Under Network press TCP/IP
- Under DNS press Manually instead of Automatically
- Now go back to the UPnP and the error popup should disappear.
(P.S. I also added Googles 8.8.8.8 address as my secondary DNS server just in case)
This should fix the error popup when entering the UPnP Port Mapping page.
- 430 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 353 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 82 Security Highlight
