Multy x app stays disconnected
Knutix
Do you have idea why My app stays disconnected? Internet connection works via multy x and phone is connected to it. Tested with Android and iOS.
#MultyX_Sep
#MultyX_Sep
May I know what is the firmware version of Multy X and the version of Multy App?
Can you share the model and O.S. version of your mobile phone?
Is the problem still exist now?
I'm having the same problem...
I have the same problem. Initial set up for the first unit worked and is currently working. Following this, I also had a “system error” message when trying to connect the second unit, which remains non-operational. At that point the App also stated “Disconnected”. Now, the App does not recognize the initial and functional WiFi name and I cannot get the second unit working. Very frustrating!!0
Can you share the screenshot about "system error" message?
Do you mean you cannot add 2nd Mutly X via Multy App?
Which mobile phone you used? What is the model and O.S. version?
Does Multy App still show "Disconnected"? Please explain more details.0 -
Base on your description, this issue happened on the installation of second Multy.
Have you try to reset the second Multy, and install it again?
Or try to reset both Multy, and use the second Multy as Root Multy to install your system.
Yes, I did the first reset. I can try the second reset of both, but prefer to know if there is a known solution.
@Hanamichi, No screenshot. When i open the App it’s as if I’ve never used it. Latest iOS on iPhone 6. I don’t know how to explain Disconnected other than immediately after the second Multy X said error, on the Home page of the App it states Disconnected. Since then as above, the App looks as if i just downloaded it. No recognition of current first Multy x unit working. As I said in my first comment it’s exactly like the comment made in June 19 that I reference0
The installation was success when you paired the first Multy, so the main problem may on the Second Multy. The only way to find out the casue is to pair the second Multy as the First one.0
Did that. Same result.
Do you mean after reset two nodes and reinstall them, 2nd node still cannot add and Multy App shows "Disconnected"? Did you switch them to install again?
What is the LED status of two nodes?
Can you share your network topology? What is the device which connected before 1st Multy X?
And which WAN type that Mutly X used?0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
