how to reset twonky media server - nas 326
Salvo_65
hi, after a virus attack the media server no longer lets me see files present in the nas, can possible to reset it or I have to proceed to a complete formatting of the nas after making a backup of the data on an external hd
#NAS_Oct_2019
Does only Twonky cannot see media files?
What if you used CIFS or NAS326's File Browser, do you able to see any media files?
yes only with twonky media serverI see the mixed files and few compared to the ones I have0
Does your volume is almost filled up? What is your RAID type?
Can you share the screenshots about the usage amount of your volume?
Please go to NAS -> Control Panel -> Service -> Media Server -> Share Publish. Deselect everything. Click Apply, and select again everything in 'Share Publish' and click 'Apply'. To check Twonky will show all the files or not.
Or you can refer this KB.
https://support.zyxel.eu/hc/en-us/articles/360000661479-Twonky-does-not-show-any-files-after-firmware-update
raid type is 1..and that's the screenshot
Have you try the workaround? Does it help in your side?
- 588 USG FLEX H Series
- 476 News and Release
