Backhaul traffic speed regression for latest version V2.20(ABKJ.2)C0
Joakim
My backhaul wifi speed got cut by 50% on the latest upgrade. Went from around 500 to 250mbps.
Can I get some help on this issue? There must be some explanation for this strange behavior.
#MultyX_Jan_2020
#MultyX_Jan_2020
Do you check Backhaul status on Multy App? How's signal strength?
To my knowledge, Multy System will select the best frequency when reboot nodes/refresh topology, below are two way to re-scan to use best frequency.
.You can refresh Backhaul by the refresh button of Multy App. (Setting > Advanced Setting > Refresh)
.Or you can reboot whole Multy System, then check it again.0 -
Hi. Thanks for the comment.Backhaul is same as before. Perfect distance and did not move. I did both the recheck and a restart. In both the results were the same.Here is some photos from before and after the latest firmware. It’s just a little strange.
Dear Sir,
The latest FW: V2.20(ABKJ.2)C0 has a different algorithm to run the test on backhaul connection than the previous firmware version, but it didn't affect the actual connection on your device.
The result is only for reference, I will recommend you to focus on the actual throughput on each node. If it didn't get effect, the backhaul connection shouldn't be a problem.
We will enhance the result of the backhaul connection when user runs the diagnose on Multy App in feature release.0 -
Thank you for the update
- 588 USG FLEX H Series
- 477 News and Release
