NAS 540 3TB unable to create volume
skynet2001
Who can help
Seagate 3TB is visible in internal disks , but no volume can be created
Maybe the file system of the HDD is incorrect? is it NTFS / EXT4 / FAT32?0
Did you go to Storage Manager > Internal Storage > Volume create to create volume like the attached pic below?
Yes i tried but without any luck, volume is not created0
HD was from other NAS drive
after apply the volume is not saved0
You can try re-format the disk on other device.
It should be applied in Linux file system format like EXT4.
https://kwilson.io/blog/format-a-linux-disk-as-ext4-from-the-command-line/
@skynet2001, You have what I had from another NAS. What you need to do is use third-party partition software to get rid of the partition first. Like GParted or something similar software. I have gone through wiping at least 2 hard drives in 2 weeks for my NAS326 (one from my old NAS and one from my old iMac)0
It is not possible to attach HD to another device
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
