NAS 540 3TB unable to create volume
skynet2001
skynet2001 Posts: 10  Freshman Member
Who can help :smile:
Seagate 3TB is visible in internal disks , but no volume can be created
«1
  • Sakura_T
    Sakura_T Posts: 101  Ally Member
    edited April 2020
    Maybe the file system of the HDD is incorrect? is it NTFS / EXT4 / FAT32?
  • Kim
    Kim Posts: 37  Freshman Member
    Did you go to Storage Manager > Internal Storage > Volume  create to create volume like the attached pic below?
  • skynet2001
    Yes i tried but without any luck, volume is not created
  • skynet2001
    HD was from other NAS drive
  • skynet2001
  • skynet2001
    after apply the volume is not saved
  • Sakura_T
    You can try re-format the disk on other device.
    It should be applied in Linux file system format like EXT4.
    https://kwilson.io/blog/format-a-linux-disk-as-ext4-from-the-command-line/
  • Emerald Dragon
    Emerald Dragon Posts: 120  Ally Member
    @skynet2001, You have what I had from another NAS. What you need to do is use third-party partition software to get rid of the partition first. Like GParted or something similar software. I have gone through wiping at least 2 hard drives in 2 weeks for my NAS326 (one from my old NAS and one from my old iMac)
  • skynet2001
    Please help , is there general software to repartition the volumes/disks
  • skynet2001
    It is not possible to attach HD to another device
