Plex for NAS326
I'm a bit confused as to how to install PLEX onto the NAS326. I have the metarepository, but unsure what to do now.
Nevermind. Figured it out, just needed a reboot.
HI
i followed the instructions provided in the linkhttps://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/
i was able to install upto MetaRepository. i'm not able to find PLEX for installation. Can you pls help me. Also the default apps are also gone. Appreciate you advice0 -
Empty the directory \\<NAS>\admin\zypkgs\MetaRepository\ and refresh the package list. If that doesn't work, post the logfiles which are made in that directory.
HI
Pls let me know where to find teh log files
also per you advice i emptied the directory
\\<NAS>\admin\zy-pkgs\MetaRepository\ and refreshed teh package. it again showed the same list
i see only these two in my list.
Appreciate your advice0 -
The logfile is ZYPKG_INFO.tgz.log. So far I can see that MetaRepository tries to download from http://downloads.zyxel.nas-central.org/Users/Mijzelf/zypkg-repo/, which doesn't exist anymore. That should be http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/fw5/ for a fw5 device (editable in the webinterface of MR), but that doesn't explain why ftp://ftp2.zyxel.com/NAS326/zypkg/5.21 also fails.The logfile should tell.
I seem to have a similar problem, about a year ago the meta repo worked perfectly, but I wanted to install plex today and I don't see any packages to install in app center.
The log file says all the fetching fails, which I don't understand.
Log:HandleZYPKG_INFO /NAS326/zypkg/5.21FindApp md5sum found /sbin/md5sumReadConfig RepositoriesStart of blockftp://ftp2.zyxel.com/+ ZyXEL/i-data/sysvol/admin/MyRepo/ LocalEnd of block9 start: 10:41:439: FetchZYPKG_INFO ftp://ftp2.zyxel.com/NAS326/zypkg/5.21/ 9 ZyXEL8 start: 10:41:438: FetchZYPKG_INFO http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/fw5/ 8 Mijzelf7 start: 10:41:437: FetchZYPKG_INFO /i-data/sysvol/admin/MyRepo/ 7 Local9: FindApp curl found /usr/bin/curl8: FindApp curl found /usr/bin/curl7: FindApp curl found /usr/bin/curl7: Fetch /i-data/sysvol/admin/MyRepo/ZYPKG_INFO.tgz /i-data/sysvol/admin/zy-pkgs/MetaRepository/_i-data_sysvol_admin_MyRepo_.tmp failed7: Fetch /i-data/sysvol/admin/MyRepo/ZYPKGS /i-data/sysvol/admin/zy-pkgs/MetaRepository/_i-data_sysvol_admin_MyRepo_.tmp failed7: Failed7 stop: 10:41:439: Fetch ftp://ftp2.zyxel.com/NAS326/zypkg/5.21/ZYPKG_INFO.tgz /i-data/sysvol/admin/zy-pkgs/MetaRepository/ftp___ftp2.zyxel.com_NAS326_zypkg_5.21_.tmp failed8: Fetch http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/fw5/ZYPKG_INFO.tgz /i-data/sysvol/admin/zy-pkgs/MetaRepository/http___zyxel.diskstation.eu_Users_Mijzelf_zypkg-repo_fw5_.tmp failed9: Fetch ftp://ftp2.zyxel.com/NAS326/zypkg/5.21/ZYPKGS /i-data/sysvol/admin/zy-pkgs/MetaRepository/ftp___ftp2.zyxel.com_NAS326_zypkg_5.21_.tmp failed9: Failed9 stop: 10:41:558: Fetch http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/fw5/ZYPKGS /i-data/sysvol/admin/zy-pkgs/MetaRepository/http___zyxel.diskstation.eu_Users_Mijzelf_zypkg-repo_fw5_.tmp failed8: Failed8 stop: 10:42:00Pushlist...ReadConfig PushlistBlacklist...ReadConfig BlacklistStart of blockYouNameItEnd of block/bin/sed -i s/^YouNameIt/#YouNameIt/I /i-data/sysvol/admin/zy-pkgs/MetaRepository/NAS326/zypkg/5.21/List.29425Sort...Choose packages...Choose DEPS...Choose SUPPKG...Create ZYPKG_INFO.tgzTarHeaderFindApp curl found /usr/bin/curlFetch /i-data/sysvol/admin/zy-pkgs/MetaRepository/NAS326/zypkg/5.21/ZYPKG_INFO.tgz - succeededI might have disabled something on the NAS, because I was trying many things (among others to install a proper package manager for the arch on the NAS btw., is it possible to get pacman?) any idea how to fix it?
When I uninstall the Metarepo app and delete zy-pkgs reloading the app list fails, when I install it again it says download list success but I get the installed apps only. The web-prefix gets always overwritten to http://localhost:59999/ and the list in web ui looks like this:# Official repositoryftp://ftp2.zyxel.com/+ ZyXEL# German mirror# German beta server# ftp://ftp.zyxel-tech.de/+ Beta# Medion server# Mijzelf's repository# Local repository/i-data/sysvol/admin/MyRepo/ Local0 -
My guess is that your box has either no DNS or no gateway:9: Fetch ftp://ftp2.zyxel.com/NAS326/zypkg/5.21/ZYPKG_INFO.tgz /i-data/sysvol/admin/zy-pkgs/MetaRepository/ftp___ftp2.zyxel.com_NAS326_zypkg_5.21_.tmp failedThat url exists.
Brilliant, fixed that on my router and all is running as it should, thanks a lot.0
Hi guys!Sorry for reviving an old thread but I believe it's better than starting a new one.Can you please let me know which one of the two available packages "*-armv7hf_neon.spk" vs ""*-armv7hf.spk" is the correct one to be installed on NAS326?Regards!
- 439 Beta Program
- 529 USG FLEX H Series
- 330 Security Ideas
- 291 Service & License
- 4.6K FAQ
