Plex for NAS326
  • mcnutty54
    mcnutty54 Posts: 2 image  Freshman Member
    Second Anniversary
    I'm a bit confused as to how to install PLEX onto the NAS326. I have the metarepository, but unsure what to do now.
  • mcnutty54
    Second Anniversary
    Nevermind. Figured it out, just needed a reboot.
  • zyxel_usr
    zyxel_usr Posts: 2 image  Freshman Member
    HI
     i followed the instructions provided in the linkhttps://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/
    i was able to install upto MetaRepository. i'm not able to find PLEX for installation. Can you pls help me. Also the default apps are also gone. Appreciate you advice
  • Mijzelf
    Mijzelf Posts: 3,051 image  Guru Member
    edited October 2020
    Empty the directory \\<NAS>\admin\zypkgs\MetaRepository\ and refresh the package list. If that doesn't work, post the logfiles which are made in that directory.
  • zyxel_usr
    HI
    Pls let me know where to find teh log files
    also per you advice i emptied the directory
    \\<NAS>\admin\zy-pkgs\MetaRepository\ and refreshed teh package. it again showed the same list
    i see only these two in my list.
    Appreciate your advice
  • Mijzelf
    The logfile is ZYPKG_INFO.tgz.log. So far I can see that MetaRepository tries to download from http://downloads.zyxel.nas-central.org/Users/Mijzelf/zypkg-repo/, which doesn't exist anymore. That should be http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/fw5/ for a fw5 device (editable in the webinterface of MR), but that doesn't explain why ftp://ftp2.zyxel.com/NAS326/zypkg/5.21 also fails.
    The logfile should tell.
  • jan_filipec
    jan_filipec Posts: 9 image  Freshman Member
    I seem to have a similar problem, about a year ago the meta repo worked perfectly, but I wanted to install plex today and I don't see any packages to install in app center.
    The log file says all the fetching fails, which I don't understand.
    Log:
    HandleZYPKG_INFO /NAS326/zypkg/5.21
    FindApp md5sum found /sbin/md5sum
    ReadConfig Repositories
    Start of block
    /i-data/sysvol/admin/MyRepo/ Local
    End of block
    9 start: 10:41:43
    9: FetchZYPKG_INFO ftp://ftp2.zyxel.com/NAS326/zypkg/5.21/ 9 ZyXEL
    8 start: 10:41:43
    7 start: 10:41:43
    7: FetchZYPKG_INFO /i-data/sysvol/admin/MyRepo/ 7 Local
    9: FindApp curl found /usr/bin/curl
    8: FindApp curl found /usr/bin/curl
    7: FindApp curl found /usr/bin/curl
    7: Fetch /i-data/sysvol/admin/MyRepo/ZYPKG_INFO.tgz /i-data/sysvol/admin/zy-pkgs/MetaRepository/_i-data_sysvol_admin_MyRepo_.tmp failed
    7: Fetch /i-data/sysvol/admin/MyRepo/ZYPKGS /i-data/sysvol/admin/zy-pkgs/MetaRepository/_i-data_sysvol_admin_MyRepo_.tmp failed
    7: Failed
    7 stop: 10:41:43
    9: Fetch ftp://ftp2.zyxel.com/NAS326/zypkg/5.21/ZYPKG_INFO.tgz /i-data/sysvol/admin/zy-pkgs/MetaRepository/ftp___ftp2.zyxel.com_NAS326_zypkg_5.21_.tmp failed
    8: Fetch http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/fw5/ZYPKG_INFO.tgz /i-data/sysvol/admin/zy-pkgs/MetaRepository/http___zyxel.diskstation.eu_Users_Mijzelf_zypkg-repo_fw5_.tmp failed
    9: Fetch ftp://ftp2.zyxel.com/NAS326/zypkg/5.21/ZYPKGS /i-data/sysvol/admin/zy-pkgs/MetaRepository/ftp___ftp2.zyxel.com_NAS326_zypkg_5.21_.tmp failed
    9: Failed
    9 stop: 10:41:55
    8: Fetch http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/fw5/ZYPKGS /i-data/sysvol/admin/zy-pkgs/MetaRepository/http___zyxel.diskstation.eu_Users_Mijzelf_zypkg-repo_fw5_.tmp failed
    8: Failed
    8 stop: 10:42:00
    Pushlist...
    ReadConfig Pushlist
    Blacklist...
    ReadConfig Blacklist
    Start of block
    YouNameIt
    End of block
    /bin/sed -i s/^YouNameIt/#YouNameIt/I /i-data/sysvol/admin/zy-pkgs/MetaRepository/NAS326/zypkg/5.21/List.29425
    Sort...
    Choose packages...
    Choose DEPS...
    Choose SUPPKG...
    Create ZYPKG_INFO.tgz
    TarHeader
    Fetch /i-data/sysvol/admin/zy-pkgs/MetaRepository/NAS326/zypkg/5.21/ZYPKG_INFO.tgz - succeeded
    I might have disabled something on the NAS, because I was trying many things (among others to install a proper package manager for the arch on the NAS btw., is it possible to get pacman?) any idea how to fix it?
    When I uninstall the Metarepo app and delete zy-pkgs reloading the app list fails, when I install it again it says download list success but I get the installed apps only. The web-prefix gets always overwritten to http://localhost:59999/ and the list in web ui looks like this:
    # Official repository
    # German mirror
    # German beta server
    # Medion server
    # Mijzelf's repository
    # Local repository
  • Mijzelf
    My guess is that your box has either no DNS or no gateway:
    That url exists.
  • jan_filipec
    Brilliant, fixed that on my router and all is running as it should, thanks a lot.
  • idet2
    idet2 Posts: 12 image  Freshman Member
    edited January 2021
    Hi guys!
    Sorry for reviving an old thread but I believe it's better than starting a new one.
    Can you please let me know which one of the two available packages "*-armv7hf_neon.spk" vs ""*-armv7hf.spk" is the correct one to be installed on NAS326?
    Regards!
