NSA325: Trouble installing MetaRepository
For reference I did a few quick speed tests before and after installing Samba 3.6.x. There is a slow down when using the newer version, but I would way rather have the improved security! Also, I don't have to keep enabling SMB 1.0 on all the families Windows 10 boxes!
Built-in Samba Speed
After installing Samba 3.6.x
Again, I am only sharing for information. I am incredibly thankful for your work and that I was able to upgrade to the latest version of Samba on this older NAS. Thanks you so much!!0 -
Hello!
When I try to install Entware on Zyxel NSA325, in logs appears some errors:--07:34:20-- http://downloads.zyxel.nas-central.org/Users/Entware-ng/binaries/armv5/installer/ld-2.22.so-2.6.24 [07:34:21] => `/opt/lib/ld-2.22.so' [07:34:21] Resolving downloads.zyxel.nas-central.org... failed: Host not found. [07:34:21] --07:34:21-- http://downloads.zyxel.nas-central.org/Users/Entware-ng/binaries/armv5/installer/libc-2.22.so-2.6.24 [07:34:21] => `/opt/lib/libc-2.22.so' <pre><code>[07:34:21] Resolving downloads.zyxel.nas-central.org... failed: Host not found.
and[07:34:21] Info: Basic packages installation... [07:34:21] /usr/local/zy-pkgs/etc/init.d/Entware-ng: line 596: /opt/bin/opkg: Input/output error [07:34:21] /usr/local/zy-pkgs/etc/init.d/Entware-ng: line 596: /opt/bin/opkg: Input/output error [07:34:21] /usr/local/zy-pkgs/etc/init.d/Entware-ng: line 596: /opt/bin/opkg: Input/output error [07:34:21] /usr/local/zy-pkgs/etc/init.d/Entware-ng: line 596: /opt/bin/opkg: Input/output error [07:34:21] /usr/local/zy-pkgs/etc/init.d/Entware-ng: line 596: /opt/bin/opkg: Input/output error [07:34:21] /usr/local/zy-pkgs/etc/init.d/Entware-ng: line 596: /opt/bin/opkg: Input/output error [07:34:21] /usr/local/zy-pkgs/etc/init.d/Entware-ng: line 596: /opt/bin/opkg: Input/output error [07:34:21] /opt/usr/lib/locale/locale-archive: No such file or directory [07:34:21] Info: Congratulations!
Also, link http://pogoplug.bplaced.net/zyxelforum/viewtopic.php?f=4&t=16 not working, server is down.
Can You to tell me where to download the libraryes 'ld-2.22.so-2.6.24' and 'libc-2.22.so-2.6.24' (alternative location or Linux disto, etc.).
Thanks in advance!
Costa0 -
Did you use the latest version of MetaRepository? Nas-central.org is down for some time now, and MetaRepository now has a trick to exchange the url by zyxel.diskstation.eu.And that libraries can be found at http://zyxel.diskstation.eu/Users/Mijzelf/Entware-ng/binaries/armv5/
Thank you for your response, Mr. Mijself!Finally, I formatted my hard disks on my Zyxel NSA 325. After this, installation of samba-replacement works 100% ok, like in your tutorial. (Old installation of meta-repository (2014?) has interfered with the new one, I think).I copied some information on my NAS, a couple of days everything has been ok (shared info's accessed without problems from Windows 10). But now, I do not kwon why, NSA 325 deny any connection over Samba (shares are not visible, but NSA still be accessed over http or ssh), or Windows 7 and Windows 10 deny all connections to this device, and returns 0x80070035.Windows firewall enabled or disabled, this does not matters.Simultaneous, all my PC's works fine with another NAS (Qnap).Do you have any suggestion for me?Thank you!0
When W7 denies to connect, it's not a SMB1 issue, as W7 supports that. So I think either Samba isn't running at all, or it has something to do with DNS. Have you checked if smbd and nmbd are actually running? Have you rebooted the NAS?About DNS, can you connect using IP address?1
Hello!
Samba version appears to be 3.6.25 (smbd -V).
I've restarted samba (samba restart), also the NSA.
In /var/log/samba/log.smbd, smbd appears to be started, no errors there.
I try to access NSA with IP address: Windows button > Run > \\192.x.y.z, or mapped into Windows explorer. Also, trying to access NSA with DNS name, the same error returned.
NSA is replaying to ping, but share are inaccessible.
Can I install Linux on device? Is there any possibilities?
Thank you!0 -
You can see if smbd/nmbd runs by executingpswhich shows all running processes, ornetstat -tulpwhich shows all listening ports (UDP and TCP) and the process (name) which has it open.Can I install Linux on device?The device is running Linux, but I suppose you mean a more common distro? Yes, that is possible, you can install Debian (link) or Arch (link).
Hi Mijzelf,
I've follow the instruction, but the opkg seem not work.
This is log from management web when i did the Entware installation.Starting up Flushing done [13:33:22] Create symlink /opt -> /usr/local/zy-pkgs/opt [13:33:22] /opt/etc/init.d/rc.unslung is not available, start installer [13:33:22] Info: Opkg package manager deployment... [13:33:22] --13:33:22-- http://pkg.entware.net/binaries/armv5/installer/opkg [13:33:22] => `/opt/bin/opkg' [13:33:22] Resolving pkg.entware.net... 172.67.212.134, 104.27.177.50, 104.27.176.50 [13:33:22] Connecting to pkg.entware.net[172.67.212.134]:80... connected. [13:33:53] HTTP request sent, awaiting response... 522 Origin Connection Time-out [13:33:53] 13:33:53 ERROR 522: Origin Connection Time-out. [13:33:53] [13:33:53] --13:33:53-- http://pkg.entware.net/binaries/armv5/installer/opkg.conf [13:33:53] => `/opt/etc/opkg.conf' [13:33:53] Resolving pkg.entware.net... 104.27.176.50, 104.27.177.50, 172.67.212.134 [13:33:53] Connecting to pkg.entware.net[104.27.176.50]:80... connected. [13:34:24] HTTP request sent, awaiting response... 522 Origin Connection Time-out [13:34:24] 13:34:24 ERROR 522: Origin Connection Time-out. [13:34:24] [13:34:24] --13:34:24-- http://pkg.entware.net/binaries/armv5/installer/libgcc_s.so.1 [13:34:24] => `/opt/lib/libgcc_s.so.1' [13:34:24] Resolving pkg.entware.net... 172.67.212.134, 104.27.176.50, 104.27.177.50 [13:34:24] Connecting to pkg.entware.net[172.67.212.134]:80... connected. [13:34:55] HTTP request sent, awaiting response... 522 Origin Connection Time-out [13:34:55] 13:34:55 ERROR 522: Origin Connection Time-out. [13:34:55] [13:34:55] --13:34:55-- http://downloads.zyxel.nas-central.org/Users/Entware-ng/binaries/armv5/installer/ld-2.22.so-2.6.24 [13:34:55] => `/opt/lib/ld-2.22.so' [13:34:55] Resolving downloads.zyxel.nas-central.org... failed: Host not found. [13:34:55] --13:34:55-- http://downloads.zyxel.nas-central.org/Users/Entware-ng/binaries/armv5/installer/libc-2.22.so-2.6.24 [13:34:55] => `/opt/lib/libc-2.22.so' [13:34:55] Resolving downloads.zyxel.nas-central.org... failed: Host not found. [13:34:55] Info: Basic packages installation... [13:34:55] /opt/usr/lib/locale/locale-archive: No such file or directory [13:34:55] Info: Congratulations! [13:34:55] Info: If there are no errors above then Entware-ng was successfully initialized. [13:34:55] Info: Found a Bug? Please report at https://github.com/Entware-ng/Entware-ng/issues [13:34:55] Execute /opt/etc/init.d/rc.unslung start [13:34:55] /usr/local/zy-pkgs/etc/init.d/Entware-ng: line 596: /opt/etc/init.d/rc.unslung: not found [13:34:55] Done /opt/etc/init.d/rc.unslung start
And this is what happened when I tried to run the command
Basically no error, but nothing happen/usr/local/zy-pkgs/opt/bin # ls -aldrwxr-xr-x 2 root root 4096 Dec 27 13:33 .drwxr-xr-x 10 root root 4096 Dec 27 13:33 ..-rwxr-xr-x 1 root root 0 Dec 27 13:33 opkg/usr/local/zy-pkgs/opt/bin # /opt/bin/opkg/usr/local/zy-pkgs/opt/bin # /opt/bin/opkg update/usr/local/zy-pkgs/opt/bin #
Please kindly suggest.0 -
Don't know exactly what is going wrong here. http://pkg.entware.net/binaries/armv5/installer/opkg gives a timeout. But when I try it here, it works fine.Further the install script tries to download http://downloads.zyxel.nas-central.org/Users/Entware-ng/binaries/armv5/installer/ld-2.22.so-2.6.24. That domain doesn't exist anymore, and MetaRepository should have exchanged it with zyxel.diskstation.eu. But the path /Users/Entware-ng/ has never existed on downloads.zyxel.nas-central.org, so I don't know where this URL comes from.
Same issue as Constantin wrote:
Found the solution here: https://zyxel.diskstation.eu/forum/viewtopic.php?f=4&t=24&start=20Hello!
"I've deleted both smbd- and nmbd-ZyXELSambaReplacement.conf.pid from /opt/var/run/, restarted the service and viola - it works again!"
Big THX to Mijzelf for his great work. Keep on like that!
Also big THX to loverman310 for solving the issue that samba doesn't restart on hard reboot.
- 415 Beta Program
- 2.4K Nebula
- 149 Nebula Ideas
- 96 Nebula Status and Incidents
- 5.7K Security
- 263 USG FLEX H Series
- 271 Security Ideas
- 1.4K Switch
- 74 Switch Ideas
- 1.1K Wireless
- 40 Wireless Ideas
- 6.4K Consumer Product
- 249 Service & License
- 387 News and Release
- 84 Security Advisories
- 29 Education Center
- 3.5K FAQ
- 73 Security Highlight
