Plex on a zyxel nas326?
Jojjothan
I bought my first NAS to use plex on it but i can't find a good tutorial on it and the text tutorials all have broken links. How do i install it?
And is there a way to have the NAS be displayed as a drive? The regular interface is really clunky and unappealing.
Some talk about docks. What is it and does it make the NAS appear as a drive so i can edit freely?
Rightclick the file, and choose 'Save link as' or equivalent.
For Plex, you can install MetaRepository as described here, scroll down for details. Then you can install a Plex installer script, which allows you to install a Synology Plex package using the webGUI.In Windows you can view the contents of a share by putting \\<nas>\<share> in the address bar of explorer. On Linux (and I think also on macOS) you can use smb://<nas>/<share>0
That is the one that is the problem. There is no web_prefix to download. It only takes me to a blank side with the link text in the corner.Mijzelf said:For Plex, you can install MetaRepository as described here, scroll down for details. Then you can install a Plex installer script, which allows you to install a Synology Plex package using the webGUI.In Windows you can view the contents of a share by putting \\<nas>\<share> in the address bar of explorer. On Linux (and I think also on macOS) you can use smb://<nas>/<share>
How do I download web_prefix?0 -
Hello
I followed all the instructions and came until this point; please check the photo on which I show you the steps that I have followed and the problem that I have encountered. Can anybody help me?
I can exactly not read what is on the Plex wrapper page. But when the server is started there should be a button on the bottom which redirects you to the webpage of the Plex server itself.
Mijzelf said:I can exactly not read what is on the Plex wrapper page. But when the server is started there should be a button on the bottom which redirects you to the webpage of the Plex server itself.
Hello @Mijzelf; As I have showed in my previeus enrty, when I clik the Web Interface link of Plex, I receive the 3rd photo (I have put below .
I say "ok" and continue. However it does not scan the files in the directory that I have defined.
Ah, I see. You entered 'Movies2' as directory? In that case the problems is that the internal directory structure is different from the 'external', as in shares you see.Try '/i-data/sysvol/Movies2' (without quotes)0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
