NR2101 firmware update V1.00(ABUS.3)C0 applied, unable to connect to internet
Moinois
I got a suggestion to update firmware of my NR2101 when I opened its interface. Now it can’t connect to internet anymore, even if it seems to have signal and I can see that there are some packages being sent and received in the statistics page. I tried to turn on roaming (shouldn’t be needed) but it didn’t make any difference.
Has anyone else experienced this?
Hello @MoinoisHave you tried the troubleshooting tips in the user guide at https://download.zyxel.com/NR2101/user_guide/NR2101_V1.0,%20Ed2.pdfI hope that this is helpful. Happy Easter.Kind regards,Tony0
Hi Moinois,
Which network mode was the NR2101 able to connect before the upgrade? Is it 4G LTE or 5G?
Can you check the setting in preference network (Settings > Network Settings > Preference Network)?
Also, can you switch the search mode to "manual" and scan the network (Settings > Network Settings)?
Do you see any of your service provider's network on the list?
Regards,
Bob0 -
First of all, I find the Zyxel support really confusing. I seem to have this support case in several systems somehow..? Not sure why, got notifications from this place as well forme some other place. I apparently answered only there.
The reason I couldn’t connect was that I had a space in the SSID. As soon as I removed it it worked just fine. Waddayaknow. So, adding support for it would be appreciated.1 -
Hi
Can the NR2101 Open a VPN Tunnel to my Zyxel Business Router?
- 601 USG FLEX H Series
- 480 News and Release
