What’s New for Nebula Mobile App 3.0?
Along with the release of P12 in Sep. at the end of 2021, Nebula has also rolled out a newly-revamped Nebula Mobile App 3.0, which focuses on the needs of small business users especially. It reorganizes the structure completely to improve the user experience by providing a brand-new, eye-catching user interface, a smoother flow design, and user-friendly features that help small business users maximize the value of using the app when managing their networks on-the-go.
Here, we will highlight some key improvements of App 3.0 and also provide a quick-check function table compared with Version 2.6 for the existing users.
- Reorganize the structure
- Wizard adds more friendly guides and instructions
New Dashboard provides cleaner site summary and function access
- WiFi page provides intuitive actions eg. create, disable/enable, share, delete
3-in-1 Devices list is able to add devices directly
- 3-in-1 Devices list is also able to get firmware notification and schedule an upgrade
New 3-in-1 Clients list with block action support
- New 3-in-1 Clients page also supports Application Visibility and Control
- Account page provides License Plan, general administrative settings and simple support contact
The function comparison table of Nebula Mobile App
v.2.6 |
v.3.0 |
Wizard/Add device process |
Hardware install guide |
No |
Yes |
LED guide |
No |
Yes |
Dashboard(Site Overview) |
Device status |
Separate by model |
Centralized(3 in 1) |
Client amount |
Only Wireless |
Wired & Wireless |
Top Wireless client |
Only amount |
Amount with Usage |
Top Gateway clients |
Top 3 with Usage |
No |
WAN throughput |
No |
Yes |
Site usage graph |
No |
Yes |
AP dashboard |
Top AP & Top SSID |
No |
Cloud saving mode |
Warning message only |
Warning & Banner (with setting) |
Notification Center |
VPN connection disconnection |
Yes |
No |
License issue related |
No |
Yes |
WiFi/SSID |
Display list |
Unfold 8 SSID by default |
Able to create/delete |
Share WiFi |
No |
Text messaging & QR code |
Security options |
Open |
Open & WPA2(Private) |
NAT mode |
Yes |
Coming soon |
Landing page |
Yes (Complicated) |
No (Coming soon Simpler) |
VLAN |
Yes |
Coming soon |
Rate limiting |
Yes |
Coming soon |
Device |
Location Map/Sitemap |
Yes |
Yes (Change & Search function coming soon) |
Entry |
From Home, Separate by model |
Independent tab (3 in 1) |
Search & Sorting |
Only Search |
Yes (Search function coming soon) |
Details |
Model name |
Model name |
Edit name |
Yes |
Yes (also could do from Wizard) |
License info |
No (Only from License tab) |
Yes |
Tag info |
No |
Yes |
Live tool |
Connection Test |
Connection Test |
Usage graph |
No |
Yes |
PoE consumption |
No |
Yes |
Port info |
Only Switch |
Switch & Gateway |
Port Details & edit |
Port name |
Port name |
Client |
Entry |
Search & Sorting |
Only Search |
Client Detail |
Name |
Name |
Usage graph |
No |
Yes |
Application Usage analysis (per client) |
No |
Yes |
Block action |
Yes (Only from client detail) |
Yes (Not only from client detail, but also direct from client list) |
Application visibility view & Action (Per Site) |
No |
Yes |
VPN topology |
Remove from v2.6 |
No |
License |
Overview |
Only NCC license |
Yes (Including security services) |
Further Details |
Only issue status |
Yes |
License Inventory |
No |
Yes |
License upgrade option |
No (Force upgrade) |
Yes |
Add License process |
No (Only support when adding devices) |
Yes (Add batch licenses process coming soon) |
Purchase license redirect to online store |
No |
Yes |
More feature/Account |
Admin Privileges |
Only user-self |
Able to see the whole org admins |
Support request |
MSP info |
MSP info |
Change org/site name |
Only site name |
Yes |
PoE schedule |
Yes |
No |
Push Notification |
Device online/offline |
Want to try the new Nebula Mobile App v3.0? Go download/update your Nebula Mobile app now!
Download here: Android version iOS version
Or scan the QR code
Please please please add back the functionality to change VLAN assignments per port, both PVID and Allowed VLANS. This was in the previous version and a very commonly used feature for our installation techs in the field. We need this again please!! Thanks!0
Hi @CPAV_Eric,
I would like to inform that the new version of Nebula APP had made some re-positioning.
We'll re-evaluate the feature you've mentioned.
Thanks for the review and for sharing your experience with the new Nebula APP 3.0.
Best regards,
JonasZyxel Nebula Support
- 441 Beta Program
- 293 Service & License
- 461 News and Release
