Zyxel NWA50AX wireless lan and Guest network
Hi @Gex ,
Thank you for raising questions.
Because NWA50AX and NWA55AX are designed for small business,
they don’t support Guest network.
The function table can be found in Nebula: Help>Device function table>SB Access point
Hope this information helps.
Silvia
Hi @Gex ,
Silvia
Thank you0
Hello!I just want to report that the following symptom was resolved by disabling “Guest Network”. It would have taken me a lot of effort to come to this conclusion by reading the documentation, so including it here for others to find.“I installed 3 new NWA50AX APs (using the Nebula App) to our existing WiFi-network (consisting of NWA210AX APs) yesterday. Everything went really well, and the new APs appeared in Nebula CC as operational. Later next day, I saw that 0 clients had connected to any of the new APs, and when I had a look at the APs, all three of them have a slow green blink (Slow Blinking (On for 1 second, Off for 1 second). According to the manual this means: “The wireless module of the Zyxel Device is disabled or fails, the Zyxel Device is using default wireless settings, or the Zyxel Device is configured to be managed by NCC but is not yet registered with the NCC”.Since there is no default wireless network on any of the APs, I assume the problem has to do with “the Zyxel Device is configured to be managed by NCC but is not yet registered with the NCC”…So what do I need to do to fix this? Thanks in advance!”0
Hi @Andreas_N ,
Welcome to Zyxel community.
If we set up some configuration that small business AP (NWA50AX) doesn’t support, then AP won’t broadcast the SSID.
We plan to enhance the warning message on applying the unsupported configuration on small business APs, and this enhancement will be released soon.
We would suggest you to use “tag” to separate the SSID for NWA50AX and NWA210.
Thank you for sharing your usage scenario, and we’re sorry for any trouble caused.
Hope the above information helps and wish you a nice day.
Silvia
Zyxel Nebula Support
Other tips:NWA50AX / NWA55AXE - Guest Mode Limitation and Intra BSS Workaround [Nebula]https://support.zyxel.eu/hc/en-us/articles/4411182876434-NWA50AX-NWA55AXE-Guest-Mode-Limitation-and-Intra-BSS-Workaround-Nebula-
Hello!
Dear @Andreas_N ,
For the issue with the NWA50AX APs, here are some troubleshooting steps for you to check the APs’ status.
1. Please install the ZON utility in your PC, connect the PC to the same LAN as the APs, then use ZON to scan and see if the APs are still accessible. Here you can download the ZON utility from our website:
https://www.zyxel.com/products_services/Zyxel-ONE-Network-Utility-ZON-Utility/
2. If you can access the local GUI of the APs from the browser, please check the Nebula connectivity status from the GUI. If the AP is managed by Nebula, it will show like this:
3. If the APs are managed by Nebula but you are unable to connect to them, please help to provide your Nebula Org/Site, and enable "Invite Zyxel support as administrator" for us to login and investigate.
Regards,
Nathan
Dear @Andreas_N,
Good day!
Regarding the issue with your NWA50AX APs, may we check with you that is our reply helpful to you? Or is the issue still persisting? If the issue is still occurring, kindly help to enable "Invite Zyxel support as administrator" in your Org/Site for us to login and investigate.
Thank you.Nathan0
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
