NR7101: PCI SCAN not working
ngervasi
I'm trying to scan PCI to be able to select some cells based on the signal quality in "Cellular Lock(LTE)" screen but the scan doesn't return any result. The unit is connecting fine but it doesn't list the available cells; broadband is set to 4G/PS Only with Band Autoselection turned on.
I'm on firmware 1.00(ABUV.4)C0 / RG502QEAAAR11A03M4G.
Any suggestions?
Any suggestions?
Same problem. It returns no results. Really important feature , hope it can be solved asap. Firmware version is V1.00(ABUV.4)C00
No change with Firmware V1.00(ABUV.5)C0 😭😭😭😭😭0
I have same issue on V.6 - does anyone know why this happens - I am UK Based.0
Latest firmware is ABUV7 and latest module is R11A07. Upgrade and it will work.1
It's still not working for me even with ABUV7 and R11A07. Any hints?0
So no reaction when you click on the yellow Scan?
Nope. Nothing happens on screen but at elast now I don't have errors in the browser console.0
Hmmmm.........
No, it's the same UI, it's just the scrollbar that hides the first options:
Current Firmware Version: 1.00(ABUV.7)C0
Current LTE Module Version: RG502QEAAAR11A07M4G
- 395 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 83 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 914 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 912 Nebula FAQ
- 415 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
