New mirror for nas-central.org
  • ehorher
    ehorher Posts: 5
    Third Anniversary
    image  Freshman Member
    well, my NSA325v2 was working fine with several applications there, so I don´t really know if I will change it....but..... Today I was trying to download the file following your advice, looking inside the URL, and noticed that the NAS can´t connect to internet, saying that "Network is unreachable", after some check, I decided to reboot the NAS, but after that never come back on line. I have the power blue light that still in solid blue, and after 30 second blink once and still in the same loop. I think that boot loader got corrupt or something like that. Im trying to connect to the console with a TTL to USB to see what happen. Please if you have some hints or procedure to recover, I appreciate that....Thanks again
  • Mijzelf
    Mijzelf Posts: 3,080
    image  Guru Member
    It depends on what is actually wrong. So first have a look at the serial output.
  • ehorher
    ehorher Posts: 5
    Third Anniversary
    I setup the TTL to 115200, 8 N 1, but I can´t see anything on the serial console. Is that correct ?
  • Mijzelf
    image  Guru Member
    No. When you power it on there should be a bootlog. Are you sure your cable is correct? If you short rx and tx, you should get a local echo. And also try to exchange rx and tx.
  • a1matt
    a1matt Posts: 3
    I created this account to say a huge thank you to @mijzelf for tirelessly supporting zykel nas owners.
    Thanks to you I was able to smoothly upgrade my NSA320 from SMBv1 to SMBv2.
    The NAS now continues to serve me well, 9 years after purchase.
  • Mijzelf
    image  Guru Member
    edited March 2022
    You're welcome.
  • Reino
    Reino Posts: 1
    First Anniversary
    Mijzelf said:
    As nas-central.org is down for several weeks now, @shv has offered some webspace and bandwidth to create a mirror of the 3th party repository. You can find it at
    If you want to put this mirror in an existing MetaRepository installation, use
    http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/fw4/ for NSA devices, and
    http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/fw5/ for NAS devices.
    Upgrade MetaRepository, as it knows some new tricks to handle mirror repos.
    #NAS_Oct_2018
    There is not any backup_app. I have BackupPlanner_001_arm_013.zpkg (NAS325 v2) and want to add it! How?
  • Mijzelf
    image  Guru Member
    This repository contains 3th party packages, and BackPlanner is a stock ZyXEL one. I'm aware ZyXEL closed their package server for older NASses, but there is a mirror, http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/zyxel_fw4_zypkgs/, which can be added to MetaRepository instead of ftp://ftp2.zyxel.com/+
  • Skala
    Skala Posts: 2 image  Freshman Member
    Hello is somewhere any repo containing myzyxelcloud-agent for NAS520?
    I would like to use myzyxelcloud and without this app a cant to find the device on internet (https://mycloud.zyxel.com/discoverer/index)
  • Mijzelf
    image  Guru Member
    You can use the NAS54x version. If you have MetaRepository installed, change the ZyXEL repo url from
    to
