Mesh doesnt work: 2 x NWA55AXE
In the "Access points" monitor, it only ever shows an empty uplink AP. When I detach one of the devices from the lan, it loses connection.
I dont see any way to debug/diagnose this issue in nebula.
Well this is even more frustrating. After waiting for ages, trying multiple times, and now posting this message it is working. How can I debug issues like this? It seems I can no longer log in to the device directly if im using nebula.0
OK - this is just as frustrating. After powercycling the non-connected device, it never brings up the wifi. It seems it needs to be connected to a LAN in order to start up. RMA time.0
Hi @rehashed
Welcome to Zyxel Community
Here is a smart mesh article for you to refer to. https://community.zyxel.com/en/discussion/10160/nebula-how-to-extend-wireless-coverage-with-smart-mesh
Please connect both APs on the wired cable and deploy them to the locations after the configuration is up to date. This way configure can confirm that it has been pushed from Nebula to Access Point.
If your mesh still doesn’t work, please let two access points connect to the LAN.
And please help us enable the "Invite Zyxel support as administrator" feature for us.
You can find it on the path of Help -> Support request and enable it (please refer to the attachment) then we can check the configuration for you.
And please PM your org/site so that we can find you.
Sincerely
Zyxel_JayPreview
I have done everything in the article mentioned, but still have problems. I have two NWA55AXE and only one is online at any given time. Smart mesh is not working even if every single configuration is done according to the article. When connecting both APs to a POE-hub (connected to a FWA710) - only one of the APs will be online. To update both APs I had to only have one connected at the time. When both were configured correct (according to article above) still same issue. It seems that the system is not configuring "Root AP" correct. What can I do to resolve this?
Hi @ChrisLau,
It seems like your FWA710 is using IP passthrough mode so only one NWA55AXE can connect to Nebula. Please disable the IP passthrough so the other NWA55AXE can also connect to Nebula to get the configuration.
Zyxel Melen1 -
Thank you! Worked like a charm 🙏
- 588 USG FLEX H Series
- 477 News and Release
