NAS540 V5.21(AATB.8)C0 inaccessible after reboot problem
MarkusDesk
I updated my NAS540 from the version V5.21(AATB.7)C0 to version V5.21(AATB.8)C0.
After that, I am unable to access the NAS after I reboot it from the webgui. This is a random problem. Sometimes I can access it after a reboot and sometimes I can't. I tried with DHCP and fixed IP, same problem! After it becomes unreachable, I need to turn it off by pressing the power button and it performs a regular shutdown.
Is this a known bug? Is it safe to downgrade? Will be a fix for it soon?
You can check the DHCP table on the router above the NAS and access the NAS with the IP address.
If the IP address is correct and do not change on the router, you can try with other browsers to access the login page of NAS, or try with incognito web pages.
Thanks for replying. Unfortunately, the problem is not that simple. If I use DHCP and if it is one of the times the NAS becomes inaccessible after reboot, the IP does not show in the DHCP leases of the router. If I set it to a fixed IP and if it is one of the times the NAS becomes inaccessible after reboot, I cannot access it by using the IP I configured. I need to turn it off manually using the power on button and turn it on again.
Maybe try with other CAT5e ethernet cable and check it again?
If the NAS is connected to the router, it should get the DHCP from the router.
SSH into NAS and type "ifconfig", you can see if the NAS get the IP from the router.
If the NAS do get the IP, you can type "top" and check if the NAS httpd works.
Hello ikubuf,Thanks for replying. The cable is ok. The problem only happens after a reboot, if I shut down the NAS and turn it on again, it works.0
You can try to downgrade to the previous firmware.There is an article discuss how to downgrade the firmware.
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
